MIL codes... can someone explain
Old Jan 17, 2014 | 03:22 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Arrow MIL codes... can someone explain
So I have been dealing with this friggin p1457 code
replaced the vent shut valve, canister, canister purge solenoid, two way valve and purge solenoid...
every time i did it i reset the CEL and LEFT the MIL code stored....
the CEL woould come on the day after a bunch of driving.. now that i have deleted the CEL and the MIL code... the cel is still gone a day later?
i checked with my scanner and it said p1457 stored in the MIL (so it came back cause i cleared it i guess)
but now my CEL is not lighting up after a day of driving like it did before.??
I cannot find any information on the MIL codes and their relation to the CEL light.. if someone could enlighten me that would be wicked... thanks
Old Jan 17, 2014 | 04:07 PM
Dead-Fox's Avatar
From what I understand (and I could be incorrect) after you reset the ECU to yellow (light will be off), there are tests performed by the computer and after a certain set of driving conditions happen (for example: you must drive 20mph, turn off the engine, drive at 50mph for a certain amount of time etc...) the ECU will reset to green if and only if there are no red flags. If there are any red flags, the the CEL light will come back on.
Old Jan 17, 2014 | 04:32 PM
YeuEmMaiMai's Avatar
p1457 leak in evap since you have removed and replaced most stuff check any remaining hoses. also a certain number of drive cycles have to be completed in order for the hard code to be cleared. also check EGR
Old Jan 18, 2014 | 07:07 AM
K well the mil code comes up first in the ecu and if it happens thre times then it triggers the cel...
Cel came on last night.
Well looks like I am leaving the car at acura today.
Hopefully it's something stupid and cheap I have missed.
Old Jan 18, 2014 | 09:50 AM
Nitin's Avatar
But I just got here
Could even be the gas cap. I had the same code earlier and just replaced the gas cap. It has been a few weeks now and the code has never come back.
Old Jan 18, 2014 | 10:41 AM
also helps to stop filling at the first click...
Old Jan 18, 2014 | 01:53 PM
Gas cap is p1456 related not p1457. I hope it ends up being a gas cap lol that would be jokes... I am dropping it off at acura today... Going to BC for some snowblading and chillout time.
Will see what acura says.. I am super curious tho I must say. I just hope it's not a killer bill.
Old Jan 18, 2014 | 08:40 PM
edman.1215's Avatar
They both have to do with the evap system though, but even with a $9 generic fuel cap from AutoZone is worth a shot:
P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
P1457 EVAP Emission Control System Leak Detected (Control Canister System)
Old Jan 19, 2014 | 08:12 PM
Car I at acura now so I will know soon enough what it is. If it is the gas cap I will gladly bow down and say you are right but I am so far lost of hope at this point it's sad
Old Jan 20, 2014 | 07:50 PM
brian6speed's Avatar
Lone Wolf
Here is a DIY for it. It is common for the valve to get rusted/stuck close or open.
http://www.6thgenaccord.com/forums/s...ad.php?t=38000
Oh wait did you say you already replaced that part?
Old Jan 21, 2014 | 01:58 AM
Yes I already did that..
Well apparently my 2 way bypass valve was stuck open somehow... The new one! I dunno what my buddy did but its fixed.. He ran the input and output test 4 times and passed everything. Did a smoke test and no leaks so its ready to rock.he said a hose was fucked up or something too... Not too sure as I am in bc and my car is in Ontario. But it took 3or 4 hours so its going to be expensive.
Jamus22
Jun 11, 2023 10:08 AM
knight rider
Mar 4, 2016 08:59 AM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
