mattg and soopa are pros! (bumper/headlight removal)
This is harrrrrrrrd! Well considering that you need the following
1) sockets: 10mm, 8mm,
2) Large phillips for 3 center screws where the grill meets the bumper, flathead screwdriver for a billion plastic clips: little bitches and big bitches.
3) MOST important of all! T-20 security socket bit, a star shaped bit with a hole in the middle to un screw a special screw on the HID low beam electrical unit.
4) Removing the roadlamp housing is ESPECIALLY a BITCH for people with Polarg M6's!
Either you're lucky and can manage for the housings to barely hang loose or the bulbs dislodge from the socket, which means a little trickey reconnection will be required.
Started at around 1:15 ish..
Hardware store run to get sidemarker/blinker amber bulbs (Sylvannia 1157A)
Had trouble with striped screw heads for about an hour...
Realized the need for T-20 socket bit
Hardware store run at 6... . Ran into some old familiar faces.
And grabbed dinner..
Dinner at 8pm
Resume working on car till midnite
BURN THE MIDNITE OIL BABY!!!
Pics to come after everything is done.
you'll get it.
http://wizardsworks.org/chod/acura/m6/
Originally Posted by mrsteve
It's midnite guys, i've met my quota! Headlamps are OPERATIONAL. All except one of the roadlamps, fuck em. I can live without them, both!
Did I mention i heard the such SWEEET SWEEET harmonious HUM of the HIDs? Awwww
how sooothing it is to my soul!
Originally Posted by mattg
let me guess... it was one of the screw/bolts on the top of the bumper.
you'll get it.
you'll get it.
It was one of the "three stooges" in the middle Where the grill would make contact with the bumper.
First time you do it it is hard.
However once you get a sense for how much pressure it takes to remove the bumper it ain't all that hard. Can do it now in like 10-15 minutes.
you'll get it.
you'll get it.
how was it harder to get the road lamps out with polarg M6 bulbs? didnt you have to shave at the socket hole anyways to get the bulb in? after that its as easy as taking out the stock bulb.
Finished product http://www.photohost.org/gallery/sho...y.php/cat/4070
I even took a picture, before I broke the styrofoam, capturing the UP arrow. LOL
emailnatec
29
09-28-2018 04:27 PM
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
AcuraKidd
09-25-2015 11:18 PM
