Magic Key Combination
3rd Gear
Hey does anyone know the magic key combination that allows us to do cool stuff with our Nav??
CL/S/Nav - Red/Ebony/Spoiler
I’m not sure this is what you are looking for, but I found this in the HELM book:
Turn the ignition switch ON
Press OK on the NAV screen
Then press and hold the keys in this order:
MENU - MAP/GUIDE - CANCEL and keep them pressed simultaneously.
After the display changes to the diagnostics menu, touch the item you want to check, and the check will start.
To return to the previous screen, touch the RETURN switch on the diagnosis screen.
This will give you access to the following menus:
System Links
Tire Calibrate
Monitor Check
Yaw Rate
Unit Check
Cyclic Diag
In Line Diag
>>> 400+ posts on h/a.net <<< >>> 550+ posts “freak” on the “old” acura-cl.com <<<
2001 CL Type S - NAV - San Marino RED / Parchment - Spoiler - 35% Tint - Roof Visor - PIAA Lamps
GOLD Emblems & Grill - V1 w/remote - KICKER ZR-360 w/(2) 10" Alumapro Subs - Shine by ZAINO
For Pictures see: PAGE 1 PAGE 2 PAGE 3 PAGE 4 V1 & SUBS
System Links
Tire Calibrate
Monitor Check
Yaw Rate
Unit Check
Cyclic Diag
In Line Diag
Oops, Shawn, you beat me (gotta be fast here)
I haven't tried it yet...
Here is the link that I think you are looking for (Its in the previous forum)
http://www.acura-tl.com/ubb/Forum15/HTML/000798.html
Search with the words "cancel" "menu" in the CL forum @ www.acura-tl.com
Hope this is what your looking for...
BTW, if anyone knows an easy way to kill some position corrections I put in. I would appreciated it. I got about 3 different schemes from Acura Care (1st didn't work, the last seemed like I would need 8 miles square of untraveled road to get it to work (a reset the nav story).
[This message has been edited by EricL (edited 01-05-2001).]
soupi
14
11-15-2015 11:15 AM
