Lower Mesh Grill DIY
Old Feb 20, 2005 | 12:27 PM
us000011's Avatar
Old&CnL
Just finished my lower grill with a mesh insert. I've been putting it off since I thought it would be difficult, but it turned out to be pretty simple- I didn't even trim the insert, and fastened it with aluminum angles and automotive 3/4" double-stick foam tape.
Before:
After:
Close-up:
Can provide details if anyone is interested.
Old Feb 20, 2005 | 01:14 PM
ccannizz11's Avatar
My Work is Done Here
what did you use for the mesh? where did you get it?
Old Feb 20, 2005 | 01:15 PM
farberstyle's Avatar
something witty
the more details the better...
Old Feb 20, 2005 | 01:57 PM
123456SPEED's Avatar
CLS 6MT Navi
Sorry, but less is better, looks like something from Shark Tale. Not a meshy.
Old Feb 20, 2005 | 03:19 PM
us000011's Avatar
Old&CnL
Mesh grill details
I used Amerimax hinged gutter guard, $2.50 a sheet for upper and lower- Ace Hardware. You have to remove the large plastic hood latch shroud, and unbolt the hold latch itself- be sure to mark the location L/R and U/D, or you will have to fiddle with it later.
Mark the mesh in the middle and crease it to match the grill contour. You may need to flatten it a little to help. Insert fro the top, in front of the radiator.
I made 4" right angle aluminum right angles, about 1" each side, and used 4 top and 4 bottom with 3/4" good auto foam tape to stick them in place. I bent the unused mesh ends around by habd to hold it side to side.
Everything on the car can be returned to stock in less than an hour with no damage.
Old Feb 20, 2005 | 03:23 PM
us000011's Avatar
Old&CnL
Shark Tales?
Actually, the camera flash highlites it more than it shows on the street; I may flat black the upper grill to play around until I get the best look. It might look better on silver.
Old Feb 20, 2005 | 07:03 PM
us000011's Avatar
Old&CnL
Long Shot
Less flash glare-
Old Feb 20, 2005 | 08:23 PM
NSXNEXT's Avatar
Decent. Might look better on a silver or white car.
I wanna see someone get it powdercoated gloss black. That would look hot.
Old Feb 20, 2005 | 09:37 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
great work...u saved a bunch of mohla too...
Old Feb 20, 2005 | 09:40 PM
RaviNJCLs's Avatar
True dat! The black will look great on your car.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rhdune16
Sep 28, 2015 11:31 AM
