Look what happened to me today...
Old 11-22-2010, 07:16 PM
StreetKA's Avatar
Angry Look what happened to me today...
First off all im still so pissed off that i really want use some gas and fire up this car after all this what happened....
Today morning i fired up car as always but there was rough idle and CEL appeard. i felt that car is vibrating and i though it was misfire... i drove the car to work nothing really happened... after work i asked my friend mechanic to check the code and we pulled 5 codes 1 2 3 and 6 cyl misfire and random misfire. i was shocked bc i car felt great and besides vibrating on idle everthing else was fine. the i took it for ride home car was fine on highway but when i got into town car start to vibrates alot more it was so sluggish i couldnt even accelerate and it did sound like subaru or something i was like wow now i was sure thats misfire but i continued drive home after i called my friend again and i told him what happened i realized that i just put few days ago my p2r thermo spacer so i thought may be something got burned or melt and i have a leak so i took it apart i removed thermo spacer i used some grease to put it back together on the old gasket... start it up again same thing... i called my friend again he told me that my injectors may be clogged so went to a store and i bought injector cleaner and filled with shell vpower to make sure its all good... then i took it for like 10 min ride i went onto highway and was trying keep the rpms about 4-5 k rpms so it will get cleaned faster... after like 6-8 min it was all gone and great and then....
BOOOOOOOM
this is exactly how it did look like when i poped the hood
as you can see there is no spark plug but i was like WHERE THE EFFF did it go ?
and here it is
it melted down there with the plastic i'll try to take a picture of it tomorrow.
The thread for spark plug is gone... i just hope that i can get a "sleeve" somwhere otherwise i have to rebuilt the heads...
i have no idea how could that happened...
anyway id make it home on 2 cylinders 4 and 5.
Old 11-22-2010, 07:19 PM
crazyasiantl's Avatar
shit
Old 11-22-2010, 07:39 PM
poisx7's Avatar
damn
i hope u can save it.
How did this happen ?
Is this the original plugs that came with your engine .
It seems sb had worked on ur car or changed ur plugs and did not tighthen them....
Old 11-22-2010, 07:41 PM
StreetKA's Avatar
i did change them 35k miles ago... it cant be that... NGK iridium just for a record
i was running on misfire and probably got flooded with fuel and then piston make so much presure that spark plug flew off but is this thread made from aluminium ? i dont think so...
Old 11-22-2010, 07:43 PM
Missing my
tnobori1's Avatar
Oh man, that sucks! I'm sorry to see this. Similar to Pits?
Old 11-22-2010, 07:51 PM
HEAVY_RL's Avatar
Received 1,041 Likes on 846 Posts
Old 11-22-2010, 07:57 PM
CH46ESeaKnight's Avatar
I can't tell in the pics, but are the threads gone? Or it might be possible that the plug backed its self out then the compression finnaly poped it out.
Old 11-22-2010, 08:00 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
Can you still run a plug in the hole or does it need to be tapped ?
Any hood damage ?
Old 11-22-2010, 08:06 PM
StreetKA's Avatar
it was BOOM then smoke and noise i pulled over that what i saw... thread is gone i mean there is no thread at all...
Old 11-22-2010, 08:09 PM
Time 2 jump on a pair of heads,early X mas present to yourself.
And tap that one for now.
Old 11-22-2010, 09:04 PM
whiteknight's Avatar
Good luck. Let us know how it turns out.
Old 11-22-2010, 09:35 PM
2Fast4you's Avatar
good opportunity to port and polish heads but man i feel for you bro
Old 11-22-2010, 10:13 PM
wham bam thank you ma'am
Rajca's Avatar
That sucks. I got a pair of heads but they will need new valves and valve seals. Also got a coil somewhere if u don't already have one
Old 11-22-2010, 10:14 PM
Sleuy1's Avatar
Damn sorry to hear about wat happen. I hope my car doesn't do the same thing because my car has been misfiring for a while now.
Old 11-23-2010, 01:48 AM
I Drive Like A Dick 8≈
Nersh7's Avatar
shitty news bro, hope you get it figured out soon
Old 11-23-2010, 03:40 AM
Chamorro
dave586270's Avatar
Damn, i just had a customer come into the shop with this on an Explorer! But she had originals plugs. Good luck man!
Old 11-23-2010, 04:06 AM
StreetKA's Avatar
Question is how did that happen ?
Old 11-23-2010, 08:11 AM
StreetKA's Avatar
Guys it looks like i need a heads or the whole new motor asap. If you know anyone selling it let me know
Old 11-23-2010, 08:40 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Any chance you stripped the sleeve when you put the plug in?
Old 11-23-2010, 09:28 AM
I got the Shifts
phee's Avatar
ive seen this happen with a cross threaded plug before. but that was on a toyota. Im really sorry to see this man. why dont you drop in your j35? just take the cams out the type-s
Old 11-23-2010, 09:40 AM
StreetKA's Avatar
You need to strip the motor change pistons swap heads and im. I have not time for that now. Ill try to fix it as it is now make new thread and see what happens. Its thanksgiving. My ody engine is not complete so for now i want to make it driveable.
I dont know hows my heads and how is my piston.
Plan for today is to fix the thread then use camera to find out whats inside then do compression test. Idk what else what can i do without taking the head off. I need to find out what is the damage.
Old 11-23-2010, 09:46 AM
ScoobyZINE
AMUA6's Avatar
Hypothetically speaking, I wonder if the plug would have gone through the hood if the coil had not been in the way?
Old 11-23-2010, 10:11 AM
inspiron0937's Avatar
Sorry to hear this man, good luck with the fix.
Old 11-23-2010, 10:33 AM
pits200's Avatar
Wow man, that is really really shitty. If anyone can empathize with your situation it's me.
As for the engine swap, you probably can find a j35 engine for under $500. When I did my swap I didn't do the cam swap. If you have a shop that can do the install, you might be able to do all of this for $1500.
I seriously have no idea how that happened, the threads should have held no matter the compression unless it was cross threaded. My spark plug got bent like a swizzle stick and it still was threaded in.
Good luck, keep us updated.
Edit: I just noticed that you said you were working on an Ody engine but it's not ready. I guess that just makes the situation even more complicated.
Old 11-23-2010, 11:33 AM
cleptosis's Avatar
shit i got a buddy with a head but non type s let me know
Old 11-23-2010, 11:40 AM
I got the Shifts
phee's Avatar
ive got a full j32a1. i can pull the head off and ship it to you. let me know whats going on and send me pics of the damage when you get them
Old 11-23-2010, 12:16 PM
Chamorro
dave586270's Avatar
You could have stripped the threads and thats why it blew out. If you know how I would try a hela coil for now. It will make new threads in the head as a temp fix till you can figure something out. Its not the best idea but you will need a new head eventually. Change the oil flush out the fuel system to get rid of any oil etc. Hela coil is just a temp fix, don't rely on it for long. Good luck!
Old 11-23-2010, 12:47 PM
StreetKA's Avatar
Whats hela coil ?
For now all my hopes in spark plug thread repair kit. It may or it may not work im gonna try it. Im affraid to say but that may be my own fault. When i purchased the car i changed the spark plugs. Probably it did tight it enough but its really hard to belive for me that i did it. I'll let you know guys with updates. Keep your finger crossed. Im looking for temporary solution for now that i will save some money and do hopefully 3.5 or 3.6.
Old 11-23-2010, 02:20 PM
Here is a little reading for you on helicoils.
http://www.popularmechanics.com/cars...repair/4212608
I would not trust it for long though. I wonder is someone over tourqed the sparkplug at one time and streched the shit out of thoes threads. The aluminium is very soft compared to iron heads.
Also in your pic of the spark plug I can't see the electrode? Is it there or is it in the cylinder? Was there an impact?
Old 11-23-2010, 02:40 PM
StreetKA's Avatar
i got the kit from autozone which looks simillar to this and its called spark plug thread repair kit...
as for pictures of spark plug
as for electrode i dont know but im pretty sure its gone
also later im gonna shot some pics of that kit and will update on progress for now
i to work on it
Old 11-23-2010, 03:15 PM
Dang.
I would stick a magnet down in the cyclinder and move it around, just in case that electrode is in the cylinder. Just make sure the magnet is secure to what ever you use. Otherwise you'll end up with a magnet stuck to your wall in the cylinder!
Old 11-23-2010, 03:16 PM
Oh and thoes threads on the spark plug look mushroomed, from overtightning. looking at the last pic.
Old 11-23-2010, 03:59 PM
StreetKA's Avatar
I tried that but every magnet i used was to big to fit. I have acces to very strong neodyme(sp?) magnets which i'll try to weld to stainlesssteel stick. Then i got to weld socket to taper and try it again tomorrow. As for now i doesnt look as bad as i thought.
Old 11-23-2010, 04:27 PM
Type CL-S's Avatar
I hope that you get your car fixed soon. I been driving with a misfire too lately but now im going to stop because i saw this. Sucks to know that at least 3 or 4 people are having the same problem at the same time.
Old 11-23-2010, 06:45 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
wow I always wondered how big of a problem improper spark plug installation can be but DAYM this one takes the cake.
OP I feel for you bro. whether it was ur fault unintentionally or not that's just not cool at all.
hope you geter fixed up a.s.a.p skip
Old 11-23-2010, 06:55 PM
StreetKA's Avatar
Imgoimg to work on it tomorrow. I have to prepare some stuff to do this properly. I hope tomorrow she will be running again. But still this is cylinder nr 6 why did i get codes on 1 2 and 3 also ? Thats confusing me. Im going to change all the sparkplugs.
Which one should i go with ? I know NGK but there is like 3 kinds of them.
Old 11-23-2010, 07:45 PM
Chamorro
dave586270's Avatar
Yeah heli coils are deff a temp fix. I'm not sure what all comes in your spark plug repair kit but i'm sure its similar. You have to try and re-thread the head strait in, then hope it holds for a while. Either way its a tricky situation. Hope you can salvage a head or figure out an alternative.
Old 11-23-2010, 08:56 PM
Former Sponsor
rondog's Avatar
Hope all goes well, sucks when your car gets sick, lol.
Old 11-23-2010, 09:03 PM
StreetKA's Avatar
^it really does
i have question...
my other motor has broken block it goes to garbage...
im looking for MDX motor now question is if it the heads can be reused on my CL if i want 3.6 build ?
or im just gonna leave the CL block get a new front cylinder head and get internals for 3.6 and RL pistons? seriously there is too much going on now and im confused as hell
Old 11-23-2010, 10:33 PM
Regional Coordinator (Texas)
nspec_ya4's Avatar
i have a perfectly good head. Just waiting on some insurance stuff to clear up, probably gonna take a month.
Quick Reply: Look what happened to me today...
