Locking Gas Cap
EVO IX MR
Locking Gas Cap
Does anyone know where to find a quality locking gas cap that will fit the 2nd Gen CL that will not leak or set off the warning alarm? The cover has a release, but that could be easily pried open. I'd hate to get a tank full of sugar sometime. Quality, nothing chintzy. Anybody got one. Thanks.
Originally Posted by Pure Adrenaline
I've always thought that the locking gas door alone was safe enough... at least in my area.
Some thoughts...
Not aware of any...
I do have a question/comment...
If you are concerned about getting a "special load" of crud tossing in your tank, then the worst damage would be from actually running the car with the gas + sugar and or other crud in it. So, if you simply looked at your gas flap and checked to see if it had been tampered with, you could arrange to have it towed away and have the tank flushed. At this point, you're looking at:
1. A busted window, door, etc to have allowed someone to get inside to flip open the gas tank door (si or no?)
2. A bent gas cover door that will need some body work and paint to get it fixed-up.
So, if someone wants to savage your car and are not a “pro” they are going to leave some tracks that you can see.
And, if someone really wants to "mess" with you -- you might consider the following:
If you get the gas tank lock, and they still are intent on screwing with you, they could:
1. Put sand in your engine (or could put a number of other items that would be rather unpleasant.
2. Put iron filing + aluminum crumbs into your intake manifold. Or they could simply toss in a handful of nuts and bolts into your air filter box. That will do some serious damage.
3. Nothing like stuffing some dirt or other crud up your tailpipe. The banana-in-the-tailpipe is no joke; if you have something stuck in your tailpipe/muffler, your NOT going anywhere and it's not obvious what's wrong. (Take my word on this one.)
So, I'm not trying to dissuade you on your quest to find more protection for your gas tank, but only letting you know that if someone really has it in for you and your wheels, they have plenty of options and I haven't even touched on some of the more sinister ones.
Finally, you might want to consider leaving a “I have a locking gas cap” sticker on the outside of the gas door -- if and when you find your locking gas cap -- as the person doing the damage may not realize this until they have cost you some $$$ in body work damage.
YMMV
YMMV
OK, see above and this might work
Ok, see if this will work for you:
GENERAL LINK:
http://www.autoparts-autoparts.com/partscategory1.jsp
THIS IS THE SPECIFIC LINK (TRY THIS ONE FIRST):
http://www.autoparts-autoparts.com/p...logo=autoparts
The top unit is the locking cap for a 2001 CL Type-S. The lower unit is the regular unit.
here is the "trail" I used to find the part:
YEAR 2001
MAKE ACURA
MODEL CL S
ENGINE V6 3.2L GAS FI ENG:J32A2
GENERAL LINK:
Code:
STANT 10504 [CAP-FUEL] Regular Locking Fuel Cap 0.00 13.48 STANT 10834 [CAP-FUEL] Regular Fuel Cap 0.00 6.01
YEAR 2001
MAKE ACURA
MODEL CL S
EVO IX MR
EVO IX MR
GENERAL LINK:
YEAR 2001
MAKE ACURA
MODEL CL S
GENERAL LINK:
Code:
YEAR 2001
MAKE ACURA
MODEL CL S
Originally Posted by 2003type-s6
Yes, I know there is a lot more than tampering w/ the gas that can be done. I just would like a little protection from the amateur if that was the case, and you pry the gas flap open with little or no damage, it has frozen on me once or twice in the winter.
And, previous link:
http://www.acura-cl.com/forums/showthread.php?t=86702
EVO IX MR
I don't think the guys who know what they are doing even need to break your window to get the doors open. Slim Jim, I was watching dateline one night and they had this electronic box thing and it took a couple seconds and your electronic locks would open, just like that. If they had one of those, they could access the hood, trunk, fuel, without breaking anything. Really, if they want it bad enough they can steal it, luckily the CL isn't on hte most wanted list. But, thanks for the link.
Feeling safe and where does it end?
Listen, most people wouldn't want to know about what good locksmiths can do and how their view of what’s "closed" and/or locked changes after a few years of "work."
BTW, they do like the HIDs on the car -- and as with anything, if someone wants to mess with you badly enough, your toast... And, a few nitwits have busted out windows to grab loose change from parked cars; I think they made off with about 90 cents.
You get what makes you "feel" safe and hope that's enough...
Otherwise you end up going with :padlock: on top of :padlock: on top of :padlock: with :padlock: and :padlock: on top of :padlock:
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
