Load rating?
Old Jan 15, 2004 | 06:55 PM
1coolcat's Avatar
Pimp Daddy Gold
Load rating?
Is there a tire in a 225/40/18 size that meets or exceeds the load rating of the stock Michelins?
Old Jan 16, 2004 | 06:28 PM
EricL's Avatar
Re: Load rating?
XL rating in a 225/40-18 is 92 and that's 1 shy of 93.
Old Jan 16, 2004 | 06:40 PM
chef chris's Avatar
Homeless
My Falken Azenis st-115 are 91 load rating.
Old Jan 16, 2004 | 06:48 PM
EricL's Avatar
93 is the load rating for the CL-S
91 is the load rating for the CL
Old Jan 16, 2004 | 07:23 PM
chef chris's Avatar
Homeless
Is there that much difference?
Old Jan 16, 2004 | 07:43 PM
EricL's Avatar
http://www.tirerack.com/tires/tirete...eral/speed.htm
Look for the load rating chart
93 --> 1433 lbs
91 --> 1356 lbs
I've generally considered 91, 92, 93 to be OK. However, just about anyone who installs tires and cares about liability will want to put a tire on the car that is equal to or greater than the factory spec.
OTOH, people do all kinds of crazy shit to their cars, and who am I to judge.
If you ever have a problem with a car's suspension, etc. and it has ANYTHING to do with the tires and they are not rated to the factory spec (V min speed rating, 93 load rating min), you might be picking up some or all of the bill -- and letting Acura off the hook.
IMHO, if I had a fixation on a 225/40-18, and I could only get it in an XL rating, I'd put it on in the 92 XL rating and just avoid filling the car up with Sumo wrestlers.
BTW, you realize that some of this rationalizing leads to people feeling that it’s just “wonderful” to put 88 SL rated tires on their cars and that’s getting kind of scary.
YMMV
Old Jan 17, 2004 | 06:25 AM
CLASSYCLS's Avatar
1-2-3-4-5-6-speeeeeed!!!!
exactly....I was looking at the BF G-force KDW2, beautiful tires with good reviews, but looking at the specs it has a low load rating of 88....200lbs less each tire, not something I want to consider when I am going into a turn with the car loaded.....I decided to go with the Yoko Parada Spec II's with its extra load capacity...great tire!!
Old Jan 17, 2004 | 10:38 AM
blader's Avatar
Audi S4 driver
my pirelli pzero rosso's will be here monday .. load rating 91, I've heard they should be ok on my cls
Old Jan 17, 2004 | 12:40 PM
CLean's Avatar
Cars are an addiction
So let me toss in a stupid question. The diff between the rating on the CL to the CL-S, is the the car or the wheels?
So I have a CL but I have CL-S wheels on it, do I need a 93 or 91 load rating???????
Old Jan 17, 2004 | 01:22 PM
EricL's Avatar
CAR
Old Jan 22, 2004 | 08:54 PM
1coolcat's Avatar
Pimp Daddy Gold
The highest load rating I found so far in a 225/40/18 is Nitto NT 555, load rating of 1389 vs. 1433 for stock. Anyone had these before, how are they?
http://www.nittotire.com/tires_555.asp
Old Jan 22, 2004 | 09:03 PM
ch1276's Avatar
I have those and have had no problems, they have actually stood up pretty well to the jersey potholes too
Old Jan 22, 2004 | 09:45 PM
chef chris's Avatar
Homeless
Looks like I estimated a bit low, but I think I'm covered.
235/40ZR18
95‡ (load rating)
28-343-893
8.5
8.0 - 9.5 Rec. Rim Width
25.3
9.6
8.3
10/32
50
1521 R (weight per tire)
Old Jan 23, 2004 | 12:46 AM
EricL's Avatar
Check out the Tire Rack page, but only select tires with XL in the description and...
Check this out:
Any of the tires on the following tire rack page with an XL in the description should be a 92 load rated tire (Continental ContiSportContact 2, Pilot Sport PS2, PZero Nero, PZero Rosso):
http://www.tirerack.com/tires/Compar..._24YR80ARXL_=4
And www.toyo.com
225/40ZR18 92WRD in A Toyo T1S
And others...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
knight rider
Mar 4, 2016 08:59 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
