Led Conversion
Old Oct 4, 2004 | 12:31 PM
GOLDMAMO's Avatar
Led Conversion
hi everybody. i was reading up on the search option about the led dash conversion. i came across this webpage. those anybody know if these kits fit our CL typeS, 2001. Sorry if this has been discuss before but i only came across the page, never found an answer if they fit our car.
thank again
here is the page
http://www.ledautomotive.com/OrderIn...cord/index.asp
Old Oct 4, 2004 | 02:56 PM
rbf351's Avatar
Registered User
you can not do the dash with LEDS, it takes alot of work and they are not just plug in type of bulbs, u need to solder about 100 leds to make it work
i tried it, it came out like this
Old Oct 4, 2004 | 03:12 PM
Chopsie's Avatar
Beware of leakage
Have you experienced any trouble yet with any burning out or technical difficulties since doing it rbf ?
Old Oct 4, 2004 | 04:13 PM
GOLDMAMO's Avatar
that looks sweet. what about the climate control and the radio part.
another thing i also read something about acteon on the gauges to clear out the green. what is that about
Old Oct 4, 2004 | 07:59 PM
rbf351's Avatar
Registered User
they burnt out constantly, and that was with the right resistance. it was just too many leds. it looked nice for a few weeks, then just went to shit
Old Oct 4, 2004 | 08:00 PM
rbf351's Avatar
Registered User
the climate and radio is the same thing, except there is no green backing to remove, just solder the leds in place of the bulbs
yes acetone is the only way to remove the green back from the gauge cluster, lots of work and just makes a mess
Old Oct 4, 2004 | 09:25 PM
Chopsie's Avatar
Beware of leakage
So all and all, it looks awesome (for a short time), but not worth the effort, correct ?
Old Oct 4, 2004 | 09:31 PM
GOLDMAMO's Avatar
rbf351, thank man i truly appriciate you honest opinion. it does look awesome but i dont want to mess up my car for some little lights.did you do your a/c and radio.? well thank you again
Old Oct 4, 2004 | 09:50 PM
rbf351's Avatar
Registered User
chopper - it definetly isn't worth it, unless you like pulling your cluster every few weeks to replace leds when they blow
yes i did the entire car
click the link to see all of it
http://www.rbf351.com/CL-S/?path=./cluster/
Old Oct 4, 2004 | 09:56 PM
Chopsie's Avatar
Beware of leakage
F- That, it's cool and all, but
Old Oct 5, 2004 | 09:54 AM
GOLDMAMO's Avatar
man that is a lot work rbf351. thank's again
Old Oct 5, 2004 | 12:41 PM
Sly Raskal's Avatar
I always thought that LED's were suppose to be better and last longer than normal bulbs because they emit less heat and require less energy.
Is there something I'm missing here?
Old Oct 5, 2004 | 12:52 PM
rbf351's Avatar
Registered User
that is true, which is why honda uses LED's on all of their new gauge clusters, but for some reason i just couldn't get it to work and neither could a few other people that tried it
Old Oct 6, 2004 | 04:52 AM
robeaneee's Avatar
it might not be worth it, but it looks damn cool
Old Oct 6, 2004 | 10:20 AM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
thank again
here is the page
What size are those ones for the map/dome/door lights?
Will those fit for us? The ones I'm using now just are bright/blue enough and those seem to be must brighter.
Old Jun 13, 2005 | 01:53 AM
racersky's Avatar
if you get the chance can you do a DIY on how you did everything? thx
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
eastcoastguy
Sep 23, 2015 06:29 AM
