View Poll Results: Which Tires?
Kuhmo
28.57%
Toyo
50.00%
Other
21.43%
Voters: 14. You may not vote on this poll
Kuhmo ECSTA Supra V. Toyo Proxes TS1
Attempting to decide between these tires. I already have a winter tire so these will be for my summer rims. I"M thinking 17x8 rim with a 235/40/17 tire size.
Kumho Ecsta Supra 712's are very good tires for the money. Otherwise they're not particularly spectacular and will not allow your car to anything beyond what you would expect an "ultra-high performance tire" (Tire Rack's classification scheme) to enable it to do.
They're a godsend for people who go through tires like water, which is why I use them as daily drivers. (Of course, I keep a set of "special event" tires/wheels for all-out performance.) They're actually kind of fun in that their lower limits allow you to play with a bit tail-out easier. That might be applicable to a 6-speed owner inclined to play with the E-brake. And you don't have to worry about losing half the tread depth after a bit of hard play, as you might with a soft-compound tire.
Points of reference:
Pirelli P6000
Yokohama AVS Intermediate
Bridgestone Potenza RE040
Bridgestone Potenza S-02
Falken Azenis Sport
Pirelli P6000
Falken Azenis Sport
I've had no problem's with my Kumho and they are GREAT for the MONEY........they are definiely ALOT stickier then stock..... Toyo's rock, but their tread wear is terrible....... expect to go through those fairly quickly.
http://www.tirerack.com/tires/tires....rehawk+SZ50+EP
treadwear for 340, excellent reviews on tirerack. and decently priced.
Yea thanks for the tips. I really didn't want to spend more than 110 per tire so the kuhmos and the toyos seemed to be the only ones out there. Since these tires would be on for about 8 months out of the year i can't have the treadwear REAL low. That's why i'm leaning towards the toyos.
when u find out, lemme know!!!
the Toyo's r in the same ballpark as our stock Michelin's, which r in the $170 area
if $110's yer budget, u may find the following tires to work
Falken GR Beta FK-451
Falken Azenis ST115
Hankook Ventus K102
Nitto NT 555 Extreme Performance
Pirelli P6000
Yokohama AVS ES100
Toyo Proxes TS1 $173/tire crap, for some reason i thought they were cheaper. Fawk.....
how much are they?
Originally posted by Scooter
where on earth r u gonna find T1-S's for $110 or less new???
Falken Azenis ST115
Hankook Ventus K102
Pirelli P6000
Yokohama AVS ES100
Falken Azenis ST115
Hankook Ventus K102
Pirelli P6000
Yokohama AVS ES100
how much are they?
they range from around 100 - 110 and up...in all honesty, yer gonna have a hard time finding a decent tire for the $$...shop around on TireRack, VictoriaTire, and Tires.com with the above tires...see what u can find
No go on the Pilot Sports........... with a treadwear rate of 220 i'll be replacing them once a year...not a chance. Looks like i might just have to bit the bullet and get the toyos.
BTW,
what is the treadwear rating on the toyos?
BTW,
check out regular Pilot Sports...with an 8in rim width, u can stick on a 255/45/17 tire!!!
the toyo's are much lighter than the kumhos. this is the reason i will be getting them, otherwise the kumhos are great. mine are even wearing fine, w/ a 3" drop, no camber kits
why did you think the toyos were inexpensive? they are crazy expensive where i live.
Originally posted by mattg
yeah, that would look neat, and you could go muddin' too
Dunno why i thought that. Yeah the kuhmos are just too heavy....even for that cheap.
Re: Kuhmo ECSTA Supra V. Toyo Proxes TS1
some food for thought ~
- your car will be faster
- you will have to lower your car a lot or it will look silly
- your speedo will be off approx 4% :o
- every 16 miles you drive, you will rack up an extra mile on the odo :'(
choose wisely, mah friend
I got my Kuhmos 235/45/17 for $95/ a peice. Out the door price from Discount Tire was $500 with warranty, install, balance, etc. I run through tires quickly cuz I drive alot. The tread on the kuhmo's, however is very noticable so everyone will know that you bought the cheapest tire. If that is an issue don't get them. I myself could care less what anyone thinks. They drive great and I still some money in my pockets.
Re: Re: Kuhmo ECSTA Supra V. Toyo Proxes TS1
Yea, i was doing the calc's just now hmmm perhaps a 225/40. Yes, i do plan on lowering the car...teinSS
Beenkurd,
hmmm i'll have to check them out. I haven't discounted anything yet Thanks for the tip!
Beenkurd,
225/45-17 owns you.
ask JRock.
225/45-17 owns you.
ask JRock.
Only reason i suggested 40 profile is i wanted a nice sport look. I"ll take some pics of my 4x4 setup tomorrow and post them......you'll see why i was shooting so low.
There is probably some wisdom in what DtEW said; the Kuhmos seem to be very inexpensive and if you need to burn up tires at auto-x events, etc , find the minimum $$$ tire that will do.
The Toyo T1S can be had for around $140-$150 depending on vendor. Treadepot.com has a website with today's prices set at:
$154 => 235/45-17 T1S
$145 => 235/40-17 T1S
In the end, it is about 40-50 bucks more per tire (about $160 - $200 pre set more).
There are some people that are "rip-offs" and are determined to charge obscene amounts for the Toyos
There is the weight issue too. The Kuhmos are heavier. The Toyos are lighter. A “guesstimate” of other brands can be obtained by calling Tire Rack (and others) and asking for the shipping weight (it's not perfect, but the “method” can give you an idea of approximate weight if you ALSO get the shipping weight of tires with published weights.).
245/40-17 T1s are being run on a non-lowered CLS with zero problems. I don't know if that setup works with the Comptechs or with lowering.
They have a lower weight than the 235/45-17 and more effective torque. They are also lighter.
The 235/40-17 (when compared to a 235/45-17) might exacerbate the SUV look (depending on drop).
Someone mentioned 255/40-17. I think that is getting "iffy" in the fit department -- you wouldn't want to lower the sucker and I think it might rub even on non-lowered cars.
if i was buying 17" again i would get this size.
Zapata if ur going Teins adjustable lower the car 1.50 all around dont believe youll need camber adjustment for 1.50 in rear. Also get the T1s in the 225/45 like Mattg said with the car lowered like that and those tires = a phat ass looking ride
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
H@mmerm@n
03-10-2002 03:54 PM
