K&N filter
Old Feb 25, 2003 | 10:29 AM
azurri10's Avatar
i will contact Astroboy about advertising
K&N filter
i was wondering if anyone knows if just putting in a K&N filter will give the car any more power at all... thanks
Old Feb 25, 2003 | 10:53 AM
dgracer's Avatar
Barely enough to feel but I use them. They do seem to eliminate that flat spot in acceleration that all cars seem to have at mid-rpm. Don't expect a big difference.
Old Feb 25, 2003 | 10:54 AM
Slimey's Avatar
Where is my super sauce?
The K&N provides higher airflow in a re-usable format. Over the long run it's cheaper then replacing the filter with disposable ones.
I don't think there is any real power gain, and I noticed no significant MPG gain either. I know the box says so, but I doubt it.
If you want gains from your intake, I'd go to a real cold air system (your choice of AEM, Injen, Comptech, or home made).
Old Feb 25, 2003 | 11:19 AM
azurri10's Avatar
thanks for the info
Old Feb 25, 2003 | 02:19 PM
sushimaster's Avatar
if you want more power with your K&N filter, remove your intake resonator.
You will need to unplug the positive lead on your battery to reset the ECU after you do this.
Old Feb 25, 2003 | 03:33 PM
Pappy's Avatar
Do it! U Only Live Once!
I've been using K&N filters for years in my cars and trucks. I like the fact that the filter can be used without replacement which saves me money. There is a power gain, but very little...I think mostly midrange.
Old Feb 25, 2003 | 04:07 PM
like I said, you need to remove the resonator on your stock intake box. It contricts air flow, and removing it increases flow, more flow, more power. And it's very easy to do. Coupled with your K&N or Comptech high flow filter, you will feel a difference.
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
jmaxima03
Sep 27, 2015 10:22 AM
