K&N Cone Filter
I Blaze Up In
K&N Cone Filter
I am picking up an intake from a member here and im gonna need to replace the cone filter with a K&N one, but Im not sure which one I need, theres like 100 different sizes and idk which one to get. All I know is that it has to be a 3" inlet, and I searched and didnt find an answer...Maybe I didnt search hard enough
So I just need the part number for a K&N cone Filter for a C.A.I
Thnx
-Mark
Thnx
-Mark
I'm Cool
I'm trying to get rid of my K+N as i do not think they are effective enuff to filter dirt. i am currently researching for a amsoil alternative for the CT icebox.
http://www.amsoil.com/StoreFront/eaau.aspx
will get back to you guys one i found the size
^ well according to that chart of part #'s apparently Amsoil doesnt have an application lol
how do u tell how much dirt yours is filtering?! i mean u arent going off-road with a CL lol
I Blaze Up In
I actually think im gonna go with the AEM Dryflow. You dont have to oil it, just rinse it with water and let it dry. And if your K&N isnt filtering well, maybe you arent oiling it enough? The oil is gonna create a type of barrier to prevent dirt and debris from going through the filter. So maybe you should try to oil it a little more and see how that works before you get the Amsoil one
-Mark
-Mark
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
![](http://farm4.static.flickr.com/3642/3442005004_efb2553f02.jpg?v=0)
RE-0910 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 5 in (127 mm)
Flange Inside Diameter: 3 in (76 mm)
Flange Length: 1.75 in (44 mm)
Flange Type: Centered
Height: 8 in (203 mm)
Top Outside Diameter: 4.625 in (117 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.42 oz (42 ml)
Flanges: 1
Inner Wire: No
Weight: 1.6 lb (0.7 kg)
Product Box Length: 6.31 in (160 mm)
Product Box Width: 6.31 in (160 mm)
Product Box Height: 10.19 in (259 mm)
This is the one I have, Fits Perfect in the bumber area with room to spare!
B A N N E D
Here is a pic of it clean..
![](http://www.knfilters.com/images/m/RE-0910.jpg)
That pic was taken after 120k miles w/o cleaning it.
I soaked it bought K@N cleaner and cleaned it then re-oiled it and workes like NEW AGAIN!
![](http://i39.tinypic.com/ih3xgx.jpg)
The "red" doesnt wrap around the piping from the icebox
The "green" can't fit because there is a plastic piece from the icebox that is in the way
Im not sure if they make sense... i maybe able to take a picture to show u
-Mark
-Mark
rcs86
08-02-2016 06:52 PM
