Jerk taking off from a stop...
Old Jul 23, 2006 | 05:11 PM
Axxie01TypeS's Avatar
When u C the L type S
I have an 01 CL-S, if u accelerate anything other than very lightly there's a jerk. Acura just checked out my transmission said it looks great & also told me that they've never replaced motor mounts on a 00 & up CL or TL... I hate it cuz I like taking off briskly but dont because of that jerk. It never jerks shifting or any other time tho. Help me plz
Old Jul 23, 2006 | 05:19 PM
All Mine's Avatar
I'm a Vagiterian.
I don't seem to have that problem.
Old Jul 23, 2006 | 05:21 PM
Stealth CL's Avatar
proffesion...axle breaker
u still under 100k?
Old Jul 23, 2006 | 05:27 PM
I have 128,000 runs flawlessly otherwise
Old Jul 23, 2006 | 05:54 PM
TallyCL-S's Avatar
about::blank
Do you hear a noise or is it just a jerk? They are most likely bullshitting you about the motor mounts.
Old Jul 23, 2006 | 06:00 PM
No noise @ all, just a jerk
Old Jul 23, 2006 | 06:19 PM
All Mine's Avatar
I'm a Vagiterian.
Torque converter going bad?
Old Jul 23, 2006 | 06:34 PM
Never thought abt the torque converter, I just dont know if thats what it is or not. Acura said it doesn't jerk, I told him it does again but I didn't feel like arguing. Someone told me motor mounts & I guess it would make sense but I just dont know. The guy @ Acura wouldn't even quote me cuz he said they just dont go bad. Errr. I say I should've thrown a tomato @ him ! hehe
Old Jul 23, 2006 | 08:26 PM
tankmonkey's Avatar
6 speed...
he's blowing sunshine up your butt. I had the front motor mount on my '01 replaced under warranty. I could hear and feel it clunking when I accelerated briskly or went up a steep driveway (in a parking garage, for instance).
haven't run into this problem yet on my '03 6mt.
Old Jul 23, 2006 | 09:26 PM
pits200's Avatar
Check the throttle cable, if your the second owner, someone might have taken all the slack out of the throttle cable as to make it more touchy. Cause I know there is suppose to be some play in the cable.
Old Jul 24, 2006 | 12:40 AM
TallyCL-S's Avatar
about::blank
If it is the front motor mount, look down at it under the hood and see if you see a brownish fluid leaking. If you have ramps you can roll the car up and look from the bottom, you will see the fluid dripping down the engine cradle from the mount. The front mount is a hydraulic one and in my last CL it went out fairly early. If you have another person you can watch the way the engine moves to see if a mount is busted.
You said you don't hear anything though, when my mount went bad I heard a deep resonating sound in the low rpms.
Old Jul 24, 2006 | 05:44 AM
iisylentii's Avatar
ALL SHOW AND NO GO
my car jerks too when i floor it from a stop. If i have the VSA off my wheels just burn out.
Old Jul 24, 2006 | 09:12 AM
Lord Helmet's Avatar
I'm here in spirit...
I don't have a "jerk" per say but I've always thought it's difficult to start from a stop smoothly in this car. The car just seems to want to take off. Then again, I've always had a bit of a lead foot from a stand-still so it might be ME with the problem, not the car.
Old Jul 24, 2006 | 05:21 PM
unlemming's Avatar
Smitty's Moral Police
I had the motor mounts replaced on both my TLs..one was an 00 and the other had a blown tranny so that didn't help the mounts.
Old Jul 24, 2006 | 06:05 PM
pits200's Avatar
Its not the mounts, if it were the mounts, he would feel it when he was shifting from Park to Drive. Like I said, its probably the throttle cable, its just tightened too much and is causing the slightest tap to make the car takeoff.
Old Jul 24, 2006 | 06:40 PM
phipark's Avatar
Not Asian
It's possible that it's the motor mounts or TC. I would go to a different dealer because they don't sound like they know what they are talking about. Also, how did they check out the tranny? They will not open it up.
Old Jul 24, 2006 | 08:04 PM
Allout's Avatar
Blown is Best
Not true. When my mounts went, the problem came to light on take off, not dropping it into gear.
Have you had your mounts replace pitts?
Old Jul 24, 2006 | 08:36 PM
pits200's Avatar
On this car, No. But on other cars when my mounts went, it was bad when I was reving or going from Drive to park. I still think its the throttle cable
Old Jul 24, 2006 | 10:19 PM
I messed w/ the throttle cable & it didn't do anything except put slack in my gas pedal...
Old Jul 24, 2006 | 10:24 PM
Titand19's Avatar
East Coast Boost.!
the title faked me out, thought it should go in D&R, didn't process the "taking"
Old Jul 25, 2006 | 09:35 AM
pits200's Avatar
Well it depends on which side you put slack on. Does your gas pedal feel touchy, or is it soft at the apex. I cant fully explain the throttle cable adjustment, but there is actually a plate on the back where the throttle lever hits, it should be against this and not away. Maybe someone has a diagram to show you what I mean.
Old Jul 25, 2006 | 09:45 AM
I'm having the same issue every time I look at the 2nd Gen discussion forum.
Old Jul 25, 2006 | 10:01 AM
RaviNJCLs's Avatar
I was having the same problem before I had my tranny replaced. They also changed the motor mounts at the same time and that solved the problem.
Same here.
Old Jul 25, 2006 | 11:09 AM
Gregory_20706's Avatar
3.2 CL-S Sundance Gold
Same here.
Yep they replaced my motormount as well when thy changed the transmission. I don't know what that guy told you (some BS), "talkin bout they don't change the motormounts on 00's and up".
Old Jul 25, 2006 | 11:44 PM
Allout's Avatar
Blown is Best
Known Problem on this car.
Old Jul 27, 2006 | 09:48 AM
Question
Well I called and priced motormounts & it turns out theres 3 for the motor & 1 for the transmission. So if it doesn't jerk in reverse just forward I should just get the back one is that right ???
Old Jul 27, 2006 | 09:56 AM
I think you need to find out if it's the mounts for sure before you buy them IMHO.
If they are busted, I think rather than replacing them with another set of stupid hydraulic m/m's that will break again, you should consider doing this... https://acurazine.com/forums/showthr...ht=motor+mount
Old Jul 27, 2006 | 09:31 PM
Thanks for the info, think i'll just do that if it's the mounts
Old Jul 27, 2006 | 11:07 PM
Feb 25, 2020 09:57 AM
NwTSXmt
3G MDX (2014-2020)
40
Dec 1, 2015 12:01 PM
SpraykwoN
ILX
Sep 24, 2015 05:20 PM
DidiBob
4G TL Problems & Fixes
Sep 23, 2015 08:14 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
