Jens:
Old Apr 3, 2001 | 02:35 PM
CLpower's Avatar
teh Senior Instigator
Jens:
i know i've asked this before. But on the 98-99 accord v6 motors it is possible to adjust the timing. My motor is essentially the same i believe, since it is in a 99 model year. Now i believe you said i can't adjust it. How come i can't change my timing. I know it's my distributer. But whats the difference between theres and mine?
Old Apr 3, 2001 | 09:43 PM
Jens H.'s Avatar
retired
CL,the distributor serves only the purpose of directing the spark down the right ignition wire the actual timing event is controlled by various sensors on the engine and the PGM-FI control unit.If you want to do something with timing it will involve reprogramming the ECU.Try contacting JET ECU they usually advertise in Sport Compact car etc.They may have a reprogrammed ECU for your car.I'll look around and see if I can find the website for them.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Old Apr 5, 2001 | 02:06 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jens Heydel:
</font>
i've had a buddy that tried them and lost power. But i'm going to look into it. Could you tell me what the 98-99 v6 accord engine has that allows them to adjust the timing???
Old Apr 5, 2001 | 04:51 PM
MCHM3's Avatar
magnet
arent they exactly the same engines
2001 cl type s,custom voltage blue paint job, comptech headers, 18 inch ssr agle strusse rims(painted voltage blue with chrome lip), greddy evo exhaust, cross drilled rotors, pioneer avx 7000 tv, playstation2, iceman cold air intake(custom)nos fuel pressure regulator, piaa ion yellow fog lights, slammed on nex suspension (level ten torque converter and b&m tranny cooler)3.5 litre upgrade on april 16!(dommed topped pistons, mdx crankshaft, rods , bearings, heads ported and polished, vtec timing
my old car www.hondatech.org/99acv6ic.html
my cl-s
http://albums.photopoint.com/j/AlbumIndex?u=1364953&a=11597233
Old Apr 5, 2001 | 05:01 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mchtypeS:
</font>
not exact. the 98-99 you can adjust the timing the 00-01 you can't
Akim711
Apr 11, 2001 12:14 AM
EricL
Mar 20, 2001 12:41 AM
