JDM Engine and Transmission
Old Sep 10, 2013 | 04:01 AM
Krisfromtampa's Avatar
4th Gear
OK new to this forum stuff and had a couple of questions i have two acura cls the one i need repaired immediately is my 02 cl type s the bottom bolt where the alternator fastens sheared apart and i keep breaking alternator brackets and i live in alaska and no one seems to be able to aluminum weld it back up for me and i also have a minor tranny issue it feels like it kind cant keep a steady pace and sometimes slips during acceleration. well i found a decent priced jdm engine and tranny that are still together and come with alternator and all the other stuff but my question is do they just drop into place and work or do i need a new ecu and wiring harness like i did for my dsm cars? any info or link eplaining all this would be greatly appreciated thanks also any place to get super good prices on parts would be appreciated also seems all the american stuff i have come across is much more expensive
Old Sep 10, 2013 | 07:34 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
Everything is the same. There are just two small outlets on the waterneck that you will have to plug/cap. They are used as tranny coolers in Japan but ours are setup different. I'm currently running a jdm motor.
Old Sep 10, 2013 | 03:51 PM
4th Gear
Well I was getting a complete package engine and tranny still together so can I use the cooler?
Old Sep 10, 2013 | 03:57 PM
6mt swapped..smart
You'll have to see how the lines are run and if the cooler is included. It could be that it was on the car itself and not included in your swap
Old Sep 10, 2013 | 04:13 PM
Karanx7's Avatar
Unregistered Member
^ Feel free to use these periods
Old Sep 10, 2013 | 04:57 PM
4th Gear
Gotcha I also was just told that I would have to transfer my crank angle sensor and my egr ?
Yikes
May 3, 2021 04:29 PM
Iakonafuji
Sep 21, 2015 02:39 PM
ghuns
Sep 16, 2015 04:26 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
