Jackpoints strong enough? :(
Old May 10, 2006 | 08:34 PM
Time For Sleeep's Avatar
That's Racist
Hi y'all; Does anyone know if the jackpoints on our 2nd gens are strong enough to hold the car up on jackstands for a couple of weeks? I've heard of people's jackstands bending and caving in.
If they're not strong enough, where should I place the stands @?
Thx in advance.
-TFS
Old May 10, 2006 | 09:04 PM
mrdeeno's Avatar
Are you talking about the jackpoints or the jackstands?
If you heard that people's jackstands are caving in, then it doesn't matter what point you put them at under the car, they'd still cave in because they weren't rated for the weight.
the jacking points on the car itself should be strong enough considering it's probably part of the chassis. just make sure you get jack stands that are rated for the weight of the car.
Old May 10, 2006 | 11:05 PM
o1s's Avatar
o1s
they are most likely strong enough. just don't do the flintstone mods like the one posted earlier this year.
Old May 11, 2006 | 01:20 AM
That's Racist
I saw the flinstones mod =D. Great fun indeed. My mistake though, I'm worried about the integrity of the jackPOINTS. The stands I believe are okay.
Old May 11, 2006 | 01:28 AM
robeaneee's Avatar
my jackstand actually bent and cause my car to fall on the rotor while the wheel was off. luckily rotor didnt crack or bend, but something you should consider.
Old May 11, 2006 | 02:13 AM
That's Racist
That's really scary... maybe I should invest in some better jackstands?
Old May 11, 2006 | 02:26 AM
robeaneee's Avatar
hell yeah it was scary i was shittin bricks. get one of those industrial ones from pep boys or something...the one on wheels where u pump the handle up and down..theyre a lot more stable
Old May 11, 2006 | 02:55 AM
VeeralS05's Avatar
I NEED MONEY!
i used my jack stand over night for painting my calipers, and they caved in some... so i wouldnt recommend it
Old May 11, 2006 | 03:12 AM
That's Racist
So if that's the case, does anyone have any suggestions for me for keeping my car in the air for a week or two?
Old May 11, 2006 | 03:20 AM
VeeralS05's Avatar
I NEED MONEY!
put it on bricks?
Old May 11, 2006 | 05:08 AM
Ken1997TL's Avatar
Use a jackstand or another object that spreads the weight better.. so you dont concentrate all that weight on a few square inches
Old May 11, 2006 | 05:10 AM
01suncls's Avatar
i just use a hydraulic lift... but not everyone has access to stuff like that i guess... uncle has one in his shop..
Old May 11, 2006 | 07:54 AM
Moodist's Avatar
I have really nice craftsman jackstands. I have used them quite a bit, without any issues.
Old May 11, 2006 | 08:27 AM
6peedSleepR's Avatar
I Heart 6 Gears.
it all depends on the qualety... buy good ones and keep your car on them for months if you would like.
Old May 11, 2006 | 09:03 AM
phipark's Avatar
Not Asian
I think a lot of people are confused here. He's not worried about the jack stands. The worry is over the jacking points and if they can withstand two straight weeks of stress.
My answer...I don't know. Sorry.
Old May 11, 2006 | 09:27 AM
Lord Helmet's Avatar
I'm here in spirit...
I wouldn't put jack stands there at all IMHO. I think it's good enough to lift one corner of the car at a time but not the whole car. Why not put your jack stands in a better place? I had my car on them overnight once with no problems when I painted my calipers. I did not use the jack points for the location of the stands though.
Old May 11, 2006 | 10:13 AM
cltypeSLOW's Avatar
Don't Mess With Texas
use the frame underneath the car as a spot to put jackstands...lift the car with jack from jack points, and put stand on frame.
Old May 11, 2006 | 11:28 AM
NiteQwill's Avatar
Adventurist.
You can lift the car from under the engine, there is a nice spot to do so. I believe Shawn S, Scalbert, and I did this. For the rear, use the tie-down hook. I've put my car on jackstands for well over 2 weeks with no problem.
I use craftsman pros. I believe they're rated at 3 tons each. With all 4, that's 6xs the amound needed to hold the car.
I would suggest using wood along with your jackpoints to support the car for long periods of time also.
Old May 11, 2006 | 12:12 PM
AuCLSman's Avatar
the jackpoints are definately strong enough. place the car on a relatively level area of pavement for stability
Old May 11, 2006 | 01:30 PM
brianlin87's Avatar
ASM I.S. Design FTW.
TFS - I had my car on jackstands @ the jackpoint for about two weeks a while ago with 4 jackstands. I also used Craftsman Pros -- great jackstands -- no problems what so ever.
Invest in better jackstands if you're worried, but for the most part you should be fine.
Old May 11, 2006 | 02:48 PM
Titand19's Avatar
East Coast Boost.!
just use any spot on the chasis in the front. There are a bunch of good places to suppot the car that are better than the weak jack points. IN the back should be the same situation
I've seen bent jack points, so I stoped using them for long periods of being off the wheels. .
Old May 11, 2006 | 07:33 PM
mnd643's Avatar
I just got mine down off the jackstands and it's been there for 3 days. no issues with caveing or bends at all. The stands are rated at 6tons...quite a bit more than you'd ever need, but my buddy lent em to me and hes got a big ass truck.
Old May 11, 2006 | 09:14 PM
ur2slow1's Avatar
6th Gear
Last year I noticed that my passenger side front jack point had collapsed and I have no idea out or when. So in my opinion they lack in structural support. I've had five acura/honda's and this has never happened before. What the deal ??
Old May 11, 2006 | 09:30 PM
mnd643's Avatar
Depends on where this "jackpoint" is collapsed...where was it set at?
Old May 11, 2006 | 10:08 PM
Stevie B's Avatar
don't trust your jack stands if you get the economy version. I had the el cheapo's one time and they just collapsed under the weight of my car, the stands are like a motorcycle helmet, just how much do you value your head or your car, a $50 helmut or a $500 helmut.
Old May 11, 2006 | 11:15 PM
artbran's Avatar
666 Speed
I heard once on TV that if you want to put your car up on jackstands, that you should but it on the suspension. This way the suspension is still compressed and is like it sitting on the ground but yet the tires are off.
Old May 12, 2006 | 01:58 AM
That's Racist
I'm actualyl fiddling with the suspension (so it'll be off the car). Otherwise, I would definitely take that into consideration.
Would it be feasible to use more than 4 jackstands (not too many more) just to spread the weight around?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
