J37a1
J37a1
Hey guys,
I have just imported 2 j37a1 engines to New Zealand to put in jet boats (They weren't available here, only j35), but neither of them came with intake manifolds. I got them for under $300 each so not too bad I thought. Can you confirm that the intake manifold and the throttle body is the same as what is on the j35a8? Our local wrecker has some cars with these engines, and I can get the IM for around $50. Id like to get a larger one but it seems these are hard to come by at wreckers over there? And I don't fancy paying more for the intake than I did for the whole engine haha.
Thanks very much
Thanks very much
I am dumb
Hey guys,
Thanks very much
Thanks very much
I am dumb
I don't believe so, no. The J37 TB, besides the MDX manifold, uses an 80mm TB, while the J35A8 uses a 67mm.
**Edit: Just realized the J37A1 is the MDX IM, which I believe is also 67mm. Either way, unless you're chasing after power, throttle body size doesn't matter. Either will work.
But since I can get a Throttle and Intake from a local wrecker here for under $100, I will do that until a can find a larger one for sale to import.
FC2012RDX
05-06-2019 09:52 PM
knoxtl
58
11-11-2014 08:09 AM
