J35a3 6 Speed
Old Jul 7, 2022 | 10:17 PM
maxmorra1's Avatar
9th Gear
J35a3 6 Speed
Wondering what 6 speed transmission will bolt up to a j35a3 from a 01 RDX . Planning on doing j35a3 block , 05 RL pistons (What crank/Rods do I run?) with my j32a2 heads and ECU . Bolted to some kind of 6 speed .Currently have a 6 speed in my CL that could be swapped. Any input on this build is appreciated, especially any wiring concerns, Thanks.
Old Jul 7, 2022 | 10:46 PM
619rcr's Avatar
this was already answered by zeta in your last thread.
Old Jul 7, 2022 | 11:03 PM
maxmorra1's Avatar
9th Gear
my b
Old Jul 7, 2022 | 11:17 PM
The first generation of RDX started in 2007; therefore, no automatic 4cyl. transmission will bolt up to a V6 J35A3 MDX block.
The only other 6MT that will bolt up to a J35A3, that I know of, is the manual trans from the 04-06 TL; however,
you would have to account for the missing #13 OEM crank sensor port provided on the CL-S MT to run the
CL-S6 ECU.
The 'spike' on the TL6 trans. gear shift lever, to connect the change wire(s), is also closer to the weight 'puck'
versus on the opposite end for the CL-S6 gear shift lever.
TL6 trans. gear shift lever:
Old Jul 7, 2022 | 11:46 PM
619rcr's Avatar
yeah, I think he meant mdx.
​​​​​​OP, j35a3 is essentially the same block with different internals. you need the 35 crank and rods for 3.5. use 89mm pistons you want. cls. rl, mdx. just make sure you swap over the cls or better valve springs if you use other heads.
there's no wiring diff if you're just changing to j35a3 block.
Old Jul 8, 2022 | 07:02 AM
UA5_6MT's Avatar
Save the Manuals
03-07 accord v6 6speed
04-06 tl 6speed 07-08 tl 6speed with 04-06 tl 6speed clutch housing case
03 cls6
Old Jul 8, 2022 | 02:18 PM
619rcr's Avatar
03 cls6
are you saying put the cls6 bellhousing on another trans gearset, because doesn't only the cls6 bell house have the mount for the trans mounted sensor?
E92Vancouver
3G MDX (2014-2020)
Nov 28, 2015 07:20 PM
pistol champ
May 11, 2013 05:21 PM
stathis
1G RDX (2007-2012)
Jul 25, 2008 08:47 PM
RL06tech
May 8, 2007 09:28 PM
