J32a2 vs j35a3
Old Oct 3, 2015 | 12:43 AM
malvothegreat's Avatar
J32a2 vs j35a3
I have an 01cl-s auto and wanted to know the comparison between the two J32A2 AND J35A3
Old Oct 4, 2015 | 09:59 AM
teh CL's Avatar
Torque
Old Oct 4, 2015 | 04:49 PM
rush's Avatar
03 acura cl type s
Best decision you'll ever make even with MPG
Old Oct 9, 2015 | 09:47 PM
gnxpro24's Avatar
J32 is higher compression, more horsepower. J35 has more torque and can be run on low octane.
Old Feb 15, 2018 | 12:03 PM
Iggy's Avatar
Can you run low octane in a J35A3 with J32A2 cams?
Old Feb 15, 2018 | 12:28 PM
horseshoez's Avatar
Latent car nut
Assuming the lift of the cams isn't so high the valves contact the pistons, you should be able to run Regular fuel with no issues.
I was reading about mixing and matching J-Series parts on a site which, unfortunately, contained as much good information as inaccurate/bad information. On that site I believe I remember a discussion about the J35A3 engines not having the same valve reliefs as used in say, the RL engine, and by changing the cams (or even the whole head), there was a risk of valve train damage. Keep in mind, this is potentially inaccurate information, but it is something to keep in mind.
Old Feb 15, 2018 | 01:54 PM
That's an interesting question.
I don't think I've ever seen that addressed/mentioned with any of the J35A3 converts.
Not sure you will get an answer from gnxpro24, though, because it appears like he has been Banned.
Old Feb 24, 2018 | 01:33 PM
Adam Kovach's Avatar
I can speak on the J35a3 block w/ J32a2 heads. There is no clearance issues. I did the frankenstein in my garage & put 3k miles on it over the summer. Not an ounce of problems. It's a beast and I easily pull on 350/370z in my 03 CLS6MT.
I am swapping out my J32a2 cams for the RL cams.
Old Feb 24, 2018 | 02:06 PM
Iggy's Avatar
I'm doing a J35A3 swap as we speak. Not swapping heads but I did swap the cams from my J32A2 into the J35.
What spark plugs are you running and what octane fuel do you burn?
Thanks.
Feel free to chime in on my swap thread https://acurazine.com/forums/second-...roject-967294/
Old Feb 24, 2018 | 03:02 PM
Spark plugs, I used whatever Honda calls for. I think the NGK laser iridium?
I use 93 octane regularly and throw about 5 gallons of 104 octane in when I take it out from hibernation in the spring.
If you have any questions on the swap, PM me and I'll give you my cell #.
Old Mar 16, 2018 | 11:18 PM
KeoCepcion's Avatar
Has anyone done an 05-08 Acura RL j35 swap? Instant 300 hp sounds real nice
I plan on doing a swap sometime soon for a lower mileage engine and if that motor is recommended then I'll definitely swing that-a-way
Old Mar 16, 2018 | 11:23 PM
horseshoez's Avatar
Latent car nut
I'm pretty sure the RL motor will not bolt into a CL due to the transmission mount being different.
Old Mar 16, 2018 | 11:26 PM
KeoCepcion's Avatar
Ah okay, can you use like the cam and intake, etc off of it and bolt it on to the j32?
Old Mar 16, 2018 | 11:27 PM
KeoCepcion's Avatar
I'm looking for around 300 hp na whether crank or wheel I'm not too worried I'm just aiming for 300 in general
Old Mar 16, 2018 | 11:32 PM
horseshoez's Avatar
Latent car nut
Refresh my memory, is your car a 6MT or an automatic?
Old Mar 16, 2018 | 11:36 PM
KeoCepcion's Avatar
It's a 6mt with a j32a1 in it as of now which is why I'm looking into swaps, if I can get to 300 whp I'll be happy for a good while.
Old Mar 16, 2018 | 11:40 PM
horseshoez's Avatar
Latent car nut
Okay, don't quote me on this, but as I understand it, those of us with the 6MT can buy the bellhousing (or whatever it is called on the Honda transmission) from the 2007-2008 TL Type-S, a different flywheel, and then allow the bolting in of the RL or the 2007-2008 TL Type-S motors. There may be a bit more to it than this, but I believe what I wrote is close.
Old Mar 16, 2018 | 11:43 PM
KeoCepcion's Avatar
Ah okay, is it by chance drive by wire? Because I rather not mess with a lot of wiring if possible :P
Mainly looking for drop in and bolt ons.
Old Mar 16, 2018 | 11:48 PM
horseshoez's Avatar
Latent car nut
Yeah, I'm pretty sure those engines are DBW. If that's the case, you might be best off with a J35A3 block and the heads from a J32A1 or J32A2.
Old Mar 17, 2018 | 12:08 AM
KeoCepcion's Avatar
Gocha, I've heard of issues with piston/valve clearance with J32a2 heads? Is this true?
Old Mar 17, 2018 | 07:08 AM
The answer to your 'piston/valve clearance' question regarding J32a2 heads on a J35a3 is in post #8 by someone who has actually done it.
In turn, he states that he's eventually installing the (I guess) 'more aggressive' cam of the RL but does not mention what year. With the 'search function' you can find it for sure. With all of that, perhaps he's close to your 300 whp goal?
Old Mar 17, 2018 | 07:12 AM
KeoCepcion's Avatar
In turn, he states that he's eventually installing the (I guess) 'more aggressive' cam of the RL but does not mention what year. With the 'search' function' you can find it for sure. With all of that, perhaps he's close to your 300 whp goal?
Ah yea, I probably should've checked the entire thread before I asked... lol, I have searched a little but some other threads were mixed reviews that I've seen
Old Mar 17, 2018 | 07:19 AM
If you click on that little J35a3 'tag' below you will instantly find 32 threads in one shape or form discussing j35a3's. Hopefully the RL cam year info can be found there.
TypeS860
Jan 10, 2026 11:11 AM
knight rider
Mar 4, 2016 08:59 AM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
iRaw
ILX
Sep 18, 2015 12:44 PM
