Intersted hese calipers from parted RL05 for cls6.
Ok, so I have slowly crept my way to the forum w/no pics and greeting msg :tomato:. Sorry for that, ok I found someone local who is parting an 05 RL and I want the calipers . These are the pics, they look bad to me. I would eventually want them on my 03cls, but are they worth buying and will I need anything for it, it looks like it is missing pieces. I am not asking what conversion kits will I need, I read other threads. They dont look they can be restored, is there something to look for to check if somethings works? I haven't offered him a price yet.
https://mail.google.com/mail/u/0/?ui...cal0&safe=1&zw https://mail.google.com/mail/u/0/?ui...cal1&safe=1&zw Saw them an was like....http://img3.imageshack.us/img3/6295/rondod.png he had the nerve to ask $400. |
u are gonna need a caliper bracket for each side. paul (nva av6) makes them. they are $180-185 and 350z brembo edition rotors. 400 is a bit much. they go for 300. just look around
Originally Posted by Rajca
(Post 14443428)
on the 3rd gen TL side; we have mathematically proved that the 2nd Gen RL calipers will upset Braking Bias.
We have NO REAL WORLD TESTING; but the math proves that you'll stop LONGER with these. Just a word of caution and might be worthy to check out the claim.
Originally Posted by 94eg!
(Post 14332467)
Okay I'm back.
RL Caliper = four 43mm pistons (5808.8 mm sq). TL Brembo = two 42mm & two 38mm piston (5039 mm sq). That's 15.3% more hydraulic area. Even to an idiot it should be plain to see you are increasing the front bias SUBSTANTIALLY just by switching installing RL calipers. But then you throw a 13 inch rotor on top of that??!?!?!? Now you are into complete Retardsville. This setup will DRASTICALLY upset bias, thereby increasing your minimum braking distance (maximum brake effort), and may even wreak havoc on your ABS system. Just ask IHC about his bogus Rotora kit. This is a terrible way to spend money and ruin a great car. http://s3.amazonaws.com/dpi_sp_image...40095-med.jpeg http://i.ebayimg.com/t/Centric-Parts..._id=89040003C1 |
Not worth $400 if you really want RL calipers check out Car-Part.com you probably find a some in better condition for less than what that guy wants. I have done this mod and its a great improvement in stopping power of OEM.
Originally Posted by clpassenubye
(Post 14443834)
I going to offer him $100 for the pair but are they worth getting period? Would degreasing and pressure cleaning get it looking good and ready? |
(Post 14443834)
by feelings? :tomato: 60-0 stop. and record how far it takes you to stop. then; some one else that doesnt have this mod do the same. (cars need to have same tires) of course, stickier tires will play a far more important role in stopping distances than brakes alone |
(Post 14443575)
We have NO REAL WORLD TESTING; but the math proves that you'll stop LONGER with these. Just a word of caution and might be worthy to check out the claim. So what would you swap them with for improvement?. Its going on a CL, and I'm not just swapping just the calibers I'm swapping the system front and will have slotted's in the back as well. |
Originally Posted by SoReal
(Post 14444070)
the calibers I'm swapping the system front and will have slotted's in the back as well. Now; I gave the data and its your turn to figure out if this is something for you and your car by researching and finding out the CL's piston sq feet and comparing it to the data above. Also, I would like to see real world test on this. to see if in fact the RL calipers do stop shorter than the CL brakes. Based on the Data above; there isnt a point for us 3G TL guys to do this swap. however, it might be different for you guise. I'm merely presenting info. |
^stay factory no swap at all?
i have rl brakes up front, i have no abs issues at all,car stops great compared to oem, and im on bigger and heavier than oem rims.......try to get them for 250-300ish........my set up is
rl calipers slotted rotors oem pads 19x9 rims with 225-35-19 tires just dont go out thinking you are ready to do road racing lol |
(Post 14444057)
and how did you test this?
Honestly for me, it was more about a look than hoping to gain improvements in the overall braking performance, however the data provided doesn't sound positive for anyone looking for gains. In a year of having them, no issues that caused any concerns and performance does seem better than stock but I'm low and slow and don't push the car and never had to test it to save myself from an accident luckily. That said, I'm guessing it's probably better than cl but TL maybe not so much? Either way, it does look 1000% better than stock cl and that was my preference.
ah, there's always two sides.
I cant argue there; they do look sexy! again, just posting data on what we have found on the 3G side |
Here more info on RL calipers
https://acurazine.com/forums/2g-cl-2001-2003-50/rl-calipers-fit-behind-05-tl-17-rims-757273/ |
Any comments towards the actual caliper that I have shown?
Originally Posted by AustinTaper
(Post 14444979)
Oh yeah this too |
(Post 14445583)
try offer him $200 then he may say $300 an you counter with $250. I only paid $250 for mine.
But if you can get it for $100 that be crazy @ss Deal :thumbsup: |
(Post 14443575)
We have NO REAL WORLD TESTING; but the math proves that you'll stop LONGER with these. Just a word of caution and might be worthy to check out the claim. Not sure the specs and sizes of your caliper pistons; but again it might be worthy to check out the claim before you spend close to a grand for these. |
Thanks for all your replies, my mind is made and its def going to be swapped.
