Interior lights
That's hot...
Interior lights
I'm getting PIAA's for my driving lights, but i think I'm gonna do a complete overhaul like AztecRol, because I can't swallow paying more for shipping then the bulbs...
So I was wondering...how hard is it to repalce the interior lights? Can I do it myself without ever having done anything like this before?
The Screeching Toyo's
Re: Interior lights
OH, wait, too late!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You don't really need any tools!!! If you have a small flat blade, this will help take the plastic covers off of the map lights. Dome light will pop off with your hand. Door lights, you will need the screwdriver. BE CAREFULL with the screwdriver, your a using metal against plastic!!! The plastic will scratch, bend very easily!!!
The trunk I think I took out with my hand as well, maybe used the flatblade. The license plate light, you will need a small phillips head screwdriver. Two screws to take off the plastic cover. If you change this bulb, make sure you note which way the plastic cover is on!!!! It is different from front to back. Lets more light forward toward the plate, then backwards toward the street!!!
It will take you 10 - 15 minutes to do all the bulbs I just mentioned!!!!
MAKE SURE YOU WEAR LATEX GLOVES!!!!! You can't touch the PIAA's with your bare hands!!! If you have any other questions, PM me, or ask them here!!!
Scooter should be posting his 2 cents soon!!!!
'Cooter
Originally posted by AztecRol
just the other day, i found 2 electrical shorts, 1 for my high beams, and 1 for my trunk light...i was like wtf!! i thought i was a victim of cheap, faulty bulbs...found out i was wrong when i 1, opened the hood, examined to find nothing wrong with the high beam bulb, and slammed the hood shut (the high beam just turned back on), and 2, i took the 19172 physically out of its trunk socket, examined, repositioned (still not on), slammed the trunk, and reopened the trunk...taadaa
still check every day and no reoccurrences...YET
That's hot...
Thanks alot for the help...
I remember reading something about the housing for the license plate lights melting on another thread...has that happened to any of you?
and how does the license plae light look?
By the way, I got 19224's and 19225's for now...they should be here by Monday ...
I know Scooter posted something about how to replace the reverse lights...
ok, let's attack the reverse first:
1. the black knobs on the inner wall of the trunk right behind the light housings are really screws to hold the lining secure...so unscrew them and pull the lining away
2. the reverse lights should b the easiest bulb to get access to, so b careful when removing the light
Is that all I need to know...do you have any other tips?
Thanks a ton
Thanks a ton
'Cooter
Thanks a ton
Thanks a ton
don't have pics of license plate light, but it looks great against the blue on my plate!!
as far as reverse bulb instructions, it's very basic and easy once u do it...after yer done, u'll realize how easy it really is no other tips are necessary
Originally posted by Scooter
no housing melting with me just yet for the license plate...the ROAD LAMP housings show signs of melting, but it's not bad
Thanks a ton
Thanks a ton
First, you are very WELCOME, that's why we are here!!!
Second, her in Cali, we have white plates, so the bluish tint that the bulb produces looks TITS on my car, especially since I have Aegean Blue Pearl!!!!! Makes the white plate have a little blue tint to it at night!!!
Third, next time you order bulbs, get the 3 sets of 19172's and one set of the 19223's. You will have an extra 223 because you only need one for the dome light. Keep it as a spare, or do what I did, I put it in my Civic!!!
handsom-hustla
11-13-2015 05:04 PM
oyayjoe
09-12-2015 04:40 PM
