Intercooler Availability
Old Mar 26, 2004 | 08:53 AM
scalbert's Avatar
In preparation of the upcoming dyno and subsequent and existing requests, I went ahead and did a BOM for the IC and determined the appropriate price for it. Below is the primary list for the intercooler and the associated parts. I was a bit surprised at the cost considering that it had been creeping up. Keeping in mind that this is a whole new upper manifold the price is very reasonable IMO.
Code:
Qty	Description
1	Intercooler Core
1	Machine Work
1	Pipe
1	Coupling
1	Reservoir
1	Heat Exchanger
1	Pump
15	Hose
8	Small Hose Clamps
2	Larger Hose Clamps
1	Gasket
14	8mm x 16mm Bolts
14	8mm x 45mm Bolts
1	1/4 NPT x 3/8 Hose, Straight
1	1/4 NPT x 3/8 Hose, Right
3	1/8 NPT x 3/16 Hose, Straight
2	3/4 NPT x 5/8 Hose, Straight
4	3/4 NPT x 5/8 Hose, Right
2	5/8 Hose Adapter
1	30 Amp Relay
1	Fuse Holder
10	Power Wire
15	Control Wire
For the complete kit as shown above the price would be: $1550.00
I also decided to provide the other options which will most likely be used in conjunction with the intercooler. They can be added on as required:
$575.00 Greddy e-Manage Main Unit, Support Tool, Ignition Harness, Injector Harness, CL/TL (5AT and 6-Speed) PnP Harness and Pre-programmed for the Intercooler Application
$125.00 8 PSI Supercharger Pulley (Requires the 3.275 Inch Alternator/Supercharger Drive Pulley)
$300.00 Polished Manifold/Intercooler and Piping Services
I haven't determined how to handle this when it comes to people purchasing. I'll probably just set up a website and allow for Paypal as some would prefer using credit cards.
As previously mentioned, dyno results will be provided soon. I expect that with the whole kit a 6-Speed should reliably make in the 370 - 380 WHP range with the 5AT making about 340 - 350 WHP.
Old Mar 26, 2004 | 09:09 AM
Chemmech's Avatar
How about us in cali, will we be able to run the hbp with 91 octane? I'm in for sure if that's the case .
Old Mar 26, 2004 | 09:16 AM
scalbert's Avatar
Yes, we'll have to back off on timing a little bit more though. That would be in the e-Manage.
Old Mar 26, 2004 | 10:15 AM
allmotor_2000's Avatar
Good stuff Steve!!
Old Mar 26, 2004 | 10:30 AM
Red-CL's Avatar
Doin' da crack shuffle
Re: Intercooler Availability
That would turn my auto tranny to jello.
Old Mar 26, 2004 | 11:23 AM
blader's Avatar
Audi S4 driver
Re: Re: Intercooler Availability
melted jello!
Old Mar 26, 2004 | 11:32 AM
Chemmech's Avatar
There goes the credit card again .
Old Mar 26, 2004 | 07:21 PM
scalbert's Avatar
Originally posted by allmotor_2000
Good stuff Steve!!
Thanks Ramanan,
It certainly has taken long enough. We may need to try something. I would love to see what type of numbers the turbo could make with this manifold and ice in the reservoir.
Old Mar 26, 2004 | 07:23 PM
scalbert's Avatar
Also, this will be available for the AV6 as I have already done the drawings for the AV6 base plate. As you can see it was not as easy since the runners are not round like with the Type-S.
AV6 Base Plate
Old Mar 26, 2004 | 07:30 PM
Satin Slayer's Avatar
aka gimmesomesugar
scalbert, as you're aware, I bought Modaddict's e-manage unit. He listed everything above except the ignition and injector harnesses and the pre-programming for the intercooler app.
On the off-chance that his does not come with those above, will you provide...
a) these harnesses...I really don't want to be splicing into anything if I don't need to.
b) pre-programming...it could possibly save me quite a bit of $$$ when it comes to dyno-tuning.
Thanks.
Old Mar 26, 2004 | 07:50 PM
mrsteve's Avatar
370-380 whp!!!! wow that is seriously impressive
Old Mar 26, 2004 | 08:35 PM
scalbert's Avatar
Although I beleive your unit will come with these from Brad, yes, I can take care of whatever the needs may be.
Old Mar 26, 2004 | 08:36 PM
scalbert's Avatar
Now for the tests though. If the new pulley comes in this week I will hopefully be able to make it to the dyno next Saturday and see what the actual results are.
Old Mar 26, 2004 | 11:31 PM
njtls2's Avatar
17 and loving it
holy crap...those numbers are insane
Old Mar 26, 2004 | 11:37 PM
mrsteve's Avatar
What does a "regular" supercharged CL-S put down?? I thought it was around 260 whp? Maybe 270?? I guess the pulley and intercooler make a huge difference.
I'm very impressed with your knowledge and ability to come up with all these new developments. Thanks for being such a pioneer for new modifications to our cars.
Old Mar 27, 2004 | 12:20 AM
Red Rider's Avatar
Subie Dubie
5AT, with Headers, Icebox and CT exhaust = 275
6MT, with Headers, Icebox and CT exhaust = 295 - 305
Old Mar 27, 2004 | 12:22 AM
Red Rider's Avatar
Subie Dubie
Scalbert, i guess the only other thing i could do is get a bullet proof tranny replacement Any recommendations ??
Old Mar 27, 2004 | 01:54 AM
TranceFusion's Avatar
very nice..... I was wondering will this work for the cl-p? How many hp will it have?
Old Mar 27, 2004 | 02:04 AM
aka gimmesomesugar
Is Dean and Velocity Resources still making the bullet-proof tranny for our cars?
Old Mar 27, 2004 | 02:18 AM
JaDia4's Avatar
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
WOW! very impressive.
Scalbert I notice you don't list all of your mods. What all do you have performance wise, if you don't mind me asking?
If you wanted to coninue to gain power what would be the next most logical mods? Changing internals like cams?
Old Mar 27, 2004 | 02:35 AM
JaDia4's Avatar
Censored User
I'm just trying to put together the chain of already produced power mods (minus the clutch & flywheel for the 5AT):
I/h/e/p/bp/flywheel/clutch/throttle body/fan & thermostat/emanage/FI/hbp/manifold -IC/?
or
I/h/e/p/bp/flywheel/clutch/throttle body/fan & thermostat/unichip/?
Old Mar 27, 2004 | 03:47 AM
CL®'s Avatar
what do you think the #'s to the wheels would be? also will this effect the entire band? thanks.
Old Mar 27, 2004 | 05:21 AM
kevin79925's Avatar
i want it!
Old Mar 27, 2004 | 05:57 AM
scalbert's Avatar
Dean may still have something in the works. I haven't heard about it lately though but it is worth dropping him a note.
Old Mar 27, 2004 | 05:58 AM
scalbert's Avatar
With the lower compression and more boost it is conceivable that a CL-P could make in the 320 WHP range.
Old Mar 27, 2004 | 06:02 AM
scalbert's Avatar
I just PM'd him asking.
Old Mar 27, 2004 | 06:07 AM
scalbert's Avatar
Comptech Headers
Comptech Supercharger
Comptech High Boost Alternator/Supercharger Pulley
King Motorsports Ported Throttle Body
Mugen T-Stat
Mugen Fan Switch
Greddy e-Manage
Custom Manifold/Intercooler
As for more power than what I expect to achieve; I haven't really looked into it yet and may not. This is currently enough for this platform IMO and more is just an exercise in futility.
Old Mar 27, 2004 | 06:08 AM
scalbert's Avatar
or
The later could get you up 275+ WHP. The former can get you about 100 WHP more but it would cost significantly more.
Old Mar 27, 2004 | 06:10 AM
scalbert's Avatar
I would estimate that a drop os 10 - 15 WHP could be realized wiht the reduced timing. And yes, the power increases are most certainly across the entire band; from idle to redline.
Old Mar 28, 2004 | 12:20 AM
MtBikR's Avatar
Look up the thread, I am running his tranny rebuild. He just needs your tranny sent in for a swap.
Old Mar 28, 2004 | 12:22 AM
MtBikR's Avatar
Steve, I'd like to get the emanage kit from you, would you have maps for high boost non;intercooled? Thanks
Old Mar 28, 2004 | 06:59 AM
scalbert's Avatar
That should not be a problem.
Old Mar 28, 2004 | 11:32 AM
brianlin87's Avatar
ASM I.S. Design FTW.
Comptech Headers
Mugen T-Stat
Mugen Fan Switch
Greddy e-Manage
so in order to "incorporate" this new intercooler into our cars, we'd need the s/c to begin with, rite?
Old Mar 28, 2004 | 04:46 PM
scalbert's Avatar
There is no point to the intercooler without forced induction of some sort.
Old Mar 28, 2004 | 06:49 PM
ModAddict's Avatar
Thanks.
It has everything but the pre-programming.
Old Mar 28, 2004 | 06:54 PM
ModAddict's Avatar
Nice work Steve!!!
Have you had a chance to do any street tuning yet?
Old Mar 29, 2004 | 09:25 AM
scalbert's Avatar
Re: Re: Re: Intercooler Availability
Which is just a single file emailed away.
Old Mar 29, 2004 | 09:29 AM
scalbert's Avatar
Just a little. I have added a little fuel up top and have removed all retard. So far there is no knock and it is running good. I got my WBO2 back and will be installing in the next couple of days. At which point I will tune further.
But I did find the weak point in a Liquid/Air IC application. I already knew this from my Typhoon but found it again. I was stopped in traffic in 85 F temps with full sun. Within 30 minutes the power was lower as the water had heated quite a bit. That is probably the biggest limitation of liquid/air systems. But at the track ice can be added for the greatest efficiency.
Old Mar 29, 2004 | 03:55 PM
ModAddict's Avatar
Would a fan (fans) on the exchanger help enough? It was part of the kit that came with the barrel type IC I started working with.
Old Mar 30, 2004 | 09:06 AM
scalbert's Avatar
I have thought of this using a temperature activated switch. I'll keep tabs on the temps too to check on the absolute need.
