Intakes Won't Fit
Old Jan 5, 2002 | 04:08 PM
scalbert's Avatar
Intakes Won't Fit
On the 6-Speed '03, the older CL-S intakes will not fit without some tinkering or redesign. Due to the change to LSD (Hrmmm???, never mind) with the deletion of VSA, the VSA throttle will not be installed.
Without the throttle, there is no place to couple the current intakes. An extension of some type would be needed. Or just go back and use the old TL/AV6 intakes, they will probably fit perfectly.
Just a little observation.
I went to the dealer today to begin negotiations, we'll probably have a contract done up and signed later this week!!! So I've already begun planning on the removal of mods in aticipation of the new 6-Speed.
Old Jan 5, 2002 | 04:30 PM
KCPreki11's Avatar
Scalbert who do you work for since you are so efficient with cars?
Old Jan 5, 2002 | 04:34 PM
EricL's Avatar
You mean on this:
Old Jan 5, 2002 | 05:29 PM
Shawn S's Avatar
What about the Xephyr design?
The one I have doesn't connect right to the throttle body.
Shawn S
Old Jan 5, 2002 | 06:10 PM
soopa's Avatar
The Creator
Originally posted by Shawn S
What about the X design?
Shawn S
yep, I would have to say that it WILL work.
i see no reason that the X wouldnt fit...
which means, that any intake will fit if you just chop 4 inches off the end and attach it the same way as the X.
Old Jan 5, 2002 | 09:47 PM
scalbert's Avatar
I stand corrected. Yes, if you attached to the the existing hose just after the airbox like X did or I did with modifying the older TL/AV6 intake:
Old Jan 5, 2002 | 11:39 PM
scalbert's Avatar
I work for a manufacturers representative firm who specializes in industrial measurement and control solutions. Basically we are the sales organization for companies that make products to go into factories.
My function is to oversee and sometimes implement the engineering aspects of the products we sell. Will they work in this application, are they cost effective, what is the ROI, etc. Then, in some cases, make it work....
My work does help with understanding the engine controls siginificantly. A PCM is not all too different from a PLC. But I do love seeing what makes something work and after being in an office all day turing a few wrenches is fun.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
drone619
Jan 26, 2016 07:09 PM
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
