intake spacer mod
#45
Whats up with RDX owners?
The suspense is killing me!!!!
![](http://www.threesources.com/simmons.jpg)
#48
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
#52
Nice
#55
direct port wet shot. along with my dry shot in the lower rpms. wet shot wont kick in till about 3k rpm and end at 7k rpm.
wont clear. modifications will need to be done. ill try to do it tomorrow before a meet. but wont have a diy bc ill be rushing.
#58
Got your mom in
^ what ecu you running?
350whp would be nice....... i may do the spacer mod too and add the P2R plenums... i know the gains are small with this mod but how much power do you think the spacer will produce?
#60
i have a spare motor.
heres the thing with wet or dry thats not direct port. each cylinder gets an diff amount of nitrous every time. it could be very little nitrous at times and more nitrous at times. a direct port wet show gives teh same amount of nitrous into each cylinder every time. its more stable and more predictable.
i will be running the greddy e-blue.
#61
just put the spacer on, had to do some cutting to the hood and spacers at the hinges. making a diy as i type. i feel and head the power. before (with bent valves) my car never broke traction in 1st. no at any mph in 1st gear, it will break the tires loose. tried it on diff pavements and speeds. also feel way better pick up in the higher rpms.
intake spacer mod FTMFW. way better than adding an intake but not quite as good as headers. anyway. for $70 not bad at all.
#67
i was in pain when i had to cut the hood for the hood pins, this was easier on me. no cf got cut, just the fiber glass, im gonn silicone the edges of the cuts so u cant see inside and maybe it will look cleaner. also weight reduction, at least a pound or two
#75
i know ours is more expensive. the way and shape the egr is positioned. u can go ahead and try it but not saying that ur nto gonna have a leak.
i bought that one and the egr was off a bit. and i dont feel like doing the job twice if i can get the right part and have it over with.
#76
'03 ABP YA4-S 6MT
#77
lowrd on tein CS biatch
yea.. rajca we all commend you for all the modding you've done to make this work. But for people like myself who just want to bolt on power and not have any extra issues because of it, what size spacer could you put in and not have any clearance issue?
I got the P2R plenums which already have LESS clearance, so what size spacer would I be able to add in there without having other issues?
#78
Not sure. The 3rd gen guy mill 7mm and don't mess with the hood. But than again, I found out that they don't have to mill the spacer and just cut the hood brace and be good. As u can tell, we can't do that. Get the p2r thermo gasket and leave it. Spending $80 for this mod,and having to mill the spacer down to about half an inch is pointless imo, that if have thr p2r plenums
#79
yea I already got thermo gaksets all of them. and they did make a difference. the plenums already protrude out of the engine bay if u pop the hood and look from the side.. i'm surprised the plenums clear as it is.. that's why i was asking, but it seems like it's pointless as you've stated... tru
