Intake manifold butterflies?
#41
MP90 uninstalled
Its important to note if I did not already that if you were going to leave the IMRC open or remove the plates and are supercharged you need to have the car properly tuned to operate that way. The tune must compensate for what the factory ECM maps will be trying to do and power delivery will then be very linear.
With out some form of tuning ability (piggy-back computer) I would either leave the IMRC disconnected if you are at 6psi of boost or leave it connected if you are at 5psi or less.
#43
MP90 uninstalled
I dont think there would be any gains on a N/A motor by removing the butterflies all together. I would leave the IMRC active so you get the gains from the lower RPM with it closed and gains at the higher RPM with it open. The harmonics of the stock Upper Intake Manifold (UIM) are most realized when the motor is Naturally Aspirated (N/A).
rcs86
08-02-2016 06:52 PM
