Installing Subwoofer
Old Aug 28, 2002 | 03:56 PM
Seattle Cl-S's Avatar
Blown LS6!!
I was wondering if anyone had directions or a website that diagrammed installing a subwoofer on our cars. I bought an Infinity Basslink and I don't feel like paying someone $100+ to hook it up. Any help? BTW, I know there exists better sound systems out there, but I just wanted a small "filler" sub.
Old Aug 28, 2002 | 04:02 PM
Titand19's Avatar
East Coast Boost.!
Silvernight should have instructions. I'm not very familiar with the basslink, but some of the other guys on the board have it. You should be able to hook it up with no prob with some help. Good luck.
Old Aug 28, 2002 | 04:30 PM
Blown LS6!!
I just read Silverknight's install. Question: Should I hook up the basslink to the head unit or the factory amp. Silverknight said you need a "good amp" if you want to tap into the factory amp. I'm assuming the basslink isn't supplied with a great amp, so is the headunit tap a better idea for good sound?
Old Aug 28, 2002 | 04:34 PM
jimcol711's Avatar
i tapped my basslink into the factory amp wiring harness...worked perfectly.....silverknight has a wiring diagram that shows what wires to tap into....its not too hard, took me about 3 hours with a freind to do the whole install from start to finish
Old Aug 29, 2002 | 09:57 AM
jimcol711's Avatar
the power of the factory amp makes no difference in how it will sound, you are simply taping into the wires to get a sound signal....not power.....from the amp...the basslink has its own amp, so thats all it needs
Old Aug 29, 2002 | 03:57 PM
Blown LS6!!
Thanks for your help. Two more quick questions - do you hook the power wire up directly to the battery (+)? And do you need to take out the back seat to run the wires to the trunk? Thanks again.
Old Aug 29, 2002 | 04:51 PM
jimcol711's Avatar
yup, run the power wire to the battery, and all you gotta really do is pop up the seat cushion and yank on the plastic trim on the inside surface of the back seat under the side window ti pull it out far enough to get your hand in there to push it through, its kind of a bitch, but it works best with 2 people...have fun, and make sure you are careful splicing into that factory wiring harness, theres tons of wires and they are very close together, just make sure you get the right ones, and dont actually cut the wire, just use one of those wire stripper tools to strip the plastic coating away from about 1/2" of the wire just enough so you can splice in.
Old Sep 4, 2002 | 11:59 PM
Blown LS6!!
I finally got around to installing the Basslink today. It sounds great, but I have one concern:
I seem to have to turn the sound up further than before to get the same level of loudness. I spliced the Basslink into the outgoing speaker wires from the factory amp. Is this correct or should I have spliced into the incoming wires from the head unit?
Old Sep 5, 2002 | 02:11 AM
Blown LS6!!
106 views and nobody knows???
Old Sep 5, 2002 | 09:48 AM
JasonT's Avatar
Should have used the input wires coming from the head unit. These are already line level, so you can splice in a pair of RCA plugs into this wire, & use the RCA inputs on the Bass Link. Jimcol711 did this recently. I have mine setup the same way, but I don't have my car now, so I can't give you the correct wiring. Do a search for BassLink in the audio section, it should be in there.
Old Sep 5, 2002 | 03:56 PM
Blown LS6!!
Thanks...it won't be hard for me to re-splice as I haven't put the trunk lining back in yet. Is there an advantage to RCA's over the speaker-level inputs? They are, after all, spliced into the same signal wires.
Old Sep 5, 2002 | 05:48 PM
SilverKnight's Avatar
Retired. Not available.
NOPE. The RCA cables are tapped into line-level wires (pre-amp). The line-converter gets the signals from speaker-level (post-amp) then converts the signals back to line-level. If you can skip it, why bother with extra steps and chances of noise getting into your system.
I did the template a while back and I didn't know much about sound system in the CL
Old Sep 5, 2002 | 08:45 PM
Goby202's Avatar
Seatle, where and how did u get those Type S Sills, that is TIGHT!! and how much did they cost
Old Sep 5, 2002 | 08:55 PM
Blown LS6!!
http://www.acura-cl.com/forums/showt...ighlight=sills
Just search through the tread. There is a phone # to call in there somewhere.
Old Sep 5, 2002 | 11:32 PM
Blown LS6!!
Ok, I just switched everything over to the RCA connectors using the line-level wires (pre-amp). Now the thing doesn't turn itself on. Is there a signal wire to tap into to run to the REM on the back of the Basslink?
The wiring info lists: (3) WHT/YEL Constant Power
(5) YEL/WHT Radio Switch
Are either of these the correct wire to tap into so the Basslink will detect a signal and turn itself on?
Geez, I know doing it yourself saves $$ and gives you self-gratification, but damn this is taking too long!
Old Sep 6, 2002 | 02:12 AM
Kalin's Avatar
Where's your 6th gear?
That's the wire that signals the amplifier to activate.
Old Sep 6, 2002 | 09:33 AM
23wt's Avatar
Mugen Racing Team
any pics of this basslink thing?
Old Sep 6, 2002 | 09:39 AM
JasonT's Avatar
Sure...
http://community.webshots.com/photo/...1891AzSlqXOBIT
http://community.webshots.com/photo/...1927mvUUDUtVTA
http://community.webshots.com/photo/...37660907KnZdKU
Old Sep 6, 2002 | 10:52 AM
Drive to Houston and I'll help you . If you need help, PM me, I'll reply with my phone number. Call me and I'll walk you through.
BTW, my log-in name is SilverKnight, not "Silvernight" as in your sig.
Old Sep 7, 2002 | 03:27 AM
Blown LS6!!
Thanks for all of your help. Got it working now. Sounds great. I'll take some pix. Sorry for the misspell SilverKnight.
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
TxRzrBk
Sep 17, 2015 01:07 PM
3GTLOwns
Sep 9, 2015 09:51 PM
