Installing a Front Strut Bar
Old Oct 6, 2004 | 10:57 AM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
Hey All,
When installing the FSB, how much tight should you screw on the bolts, ftlbs? Was thinking of having someone install it, but might as well buy a torque wrench and do it myself
Old Oct 6, 2004 | 01:00 PM
phipark's Avatar
Not Asian
I just tightened mine until it was good and tight. Definitely don't have someone install it, takes about 15-30 min.
Old Oct 6, 2004 | 01:04 PM
Silverbulit40's Avatar
Enjoy the Ride
WERD! One of the easiest installs
Old Oct 6, 2004 | 01:11 PM
FunkeeTown's Avatar
friend of fast
yep, tighten it as much as you can and that would be it.
i had front and rear strut bars on my car in hs and that's all it took. maybe retighten every 3 months or so.
Old Oct 6, 2004 | 01:27 PM
RaptorCLS's Avatar
yeah..i figure it would be a lot easier than the exhausts and CAI I put in....just got spooked when I read about the 'factory torque specs' it mentioned.
Old Oct 6, 2004 | 07:53 PM
NiteQwill's Avatar
Adventurist.
12 ft/lbs
Old Oct 7, 2004 | 12:27 AM
Allout's Avatar
Blown is Best
12 ft/lbs on the two small bolts that hold down the stock strut bar.
37 ft/lbs on the three larger bolts.
Old Oct 7, 2004 | 07:31 AM
RaptorCLS's Avatar
what the hell???? What holds the two parts that go to the back? I couldnt feel any bolts underneath there.
Old Oct 7, 2004 | 08:11 AM
phipark's Avatar
Not Asian
Ok, are you sure you are talking about the STB? There are two bolts that hold the STB and then the other three hold the shock, I think? You shouldn't be doing anything underneath anything, it's all on top in plain sight.
Old Oct 7, 2004 | 02:40 PM
Allout's Avatar
Blown is Best
Let's clarify, are we talking about an Upper or Lower strut bar? I was referring to an Upper.
Old Oct 7, 2004 | 07:49 PM
RaptorCLS's Avatar
Below is a cheesy diagram of what is there
about a 1/4 of the way from each side going inward are two bars (welded) that go straight back towards the car that are attached to the top underneath.
Old Oct 7, 2004 | 09:50 PM
RaptorCLS's Avatar
blah...for some reason its not showing the lines I drew for the two other bars.
acurajj
Feb 14, 2016 02:28 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Heyzuez20
Oct 14, 2015 07:18 AM
08 NBP TL
Sep 8, 2015 08:49 PM
