Inspection Plate Location?
Old Feb 1, 2010 | 06:32 PM
CollinCL's Avatar
Hey anyone got a pic of the inspection plate so I can access the flywheel on an auto? Or can you snap one for me real quick? I'm trying to tighten the crank pulley bolt and I need to lock up the flywheel. Cars torn apart in the driveway right now and it's getting dark out .. guess I shoulda done more research first. I found some descriptions of where it is by searching but hey I'm a visual learner so pics FTW! Thanks guys.
Old Feb 1, 2010 | 06:38 PM
CLSspeedx's Avatar
I have a 6 speed, but I can put up an illustration from my Helms if I find a decent one. Will that work?
Old Feb 1, 2010 | 06:56 PM
CLSspeedx's Avatar
Damn can't edit... well try here https://acurazine.com/forums/showthr...ction+flywheel
Thanks to civicdrvr:
Look where the tranny meets the block. There will be a small plate the is shaped like a C. I think its held on with 4 10mm bolts. Thats the inspection plate.
Old Feb 1, 2010 | 08:43 PM
CollinCL's Avatar
Thanks I actually saw that already I was hoping for a picture as I couldn't find it based upon that description but I had my brother lock up the power steering pump while I tightened the crank.. hope that holds until I can get ahold of some air tools. (got it up to 110 already and it did't fly off!)
If you can get ahold of a picture from the helms manual that'd be great.
Old Feb 1, 2010 | 08:51 PM
fsttyms1's Avatar
Go under the car. Look at where the trans meets the motor. There is a plate there held on with a few 10 mm bolts.
Old Feb 1, 2010 | 08:55 PM
fsttyms1's Avatar
its the one by #39
Old Feb 1, 2010 | 09:39 PM
MrFluffy's Avatar
To many cars in my garage
I looked for that, and your rite it is hard to find good luck I used air tools
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
