Injen CAI and Bypass broke. Can I run short ram?
trying to get a lil V-I
I heard a weird humming noise from my engine last night when I started her up. I popped my hood to find the AEM bypass valve had split and was leaking air. I then looked to see what might have caused this and I noticed that the rubber mount piece holding the bottom half of the Injen intake had ripped off and the weight of the CAI had split the bypass valve
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
So I yanked the entire bottom half off and took the air filter and plugged it on the top half of the intake...where the bypass valve used to be.
Is there a problem running like this? It definitely idles much louder and still has a weird humming noise...really dam annoying. Has anyone done this?
Sorry to hear the demise of your CAI
Short ram is ok, but you may want to disconnect the battery to have it reset like you did with the CAI. However, in the long run, you are not getting as much gain as the CAI due to high temperature under the hood.
supposedly disconnecting your battery resets the ECU making it relearn with the new mod. If you don't do that, it will just relearn slowly over time, you're fine.
Re: So
Originally posted by Smitty
You never made it to HOME DEPOT last night?
picked up a 3" rubber tubing... but it turns out it was the "Extra" large 3" rubber tubing... so I basically got screwed. They didn't have anything else so I said f-it...
plus that was when I noticed the rubber mount that attaches to the side wall of my car was ripped off.
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
