Imrc
Imrc
Ok I searched under the "problem and fixes" section and only found 5 or 6 posts that did not help me.
I noticed powerloss below 4k rpm nad checked the IRMC and it's no longer working. It was fine last month cause I checked it. So it feels a little tight when I move it by hand. I'm going to go check for voltage here in a sec at the plug. Is there anything I should know before buying a new one?
Does anyone have the part # for a 01 CLS IMRC valve? I looked on OEMAcuraparts but there was like nine valves and no indication as to wich one I needed.
Originally Posted by Mike
Hey, thanks man.
I did not seem to get any voltage from the plug.??????? Not 100% sure I was able to make contact with the leads though.
Is there a fuse? Just a shot in the dark!
Inside the actuator, that's the part back by the firewall....there is a gear I believe that gets stripped. Some guys have taken it apart and found that to be the problem. Try that.
Moderator Alumnus
Originally Posted by CH46ESeaKnight
Hey, thanks man.
look through there. I set up the Type-S manifold and imrc on my old clp. I found out what prong was powered.
EricL
07-25-2002 02:12 AM
EricL
2G CL Frequently Asked Questions
07-24-2002 03:51 PM
