I'm planning to Drop my CL-S a 1.5"inch, will that affect my alignment????!!
Hey guys I just got my CL-S for about a year now and I'm planning on to hook it up...but now I'm in the process of Dropping it a 1.5' inch...do I need any alignment adjustment....will I lose my comfort as like my stock springs???????
Originally posted by GEOKI:
<STRONG>Hey guys I just got my CL-S for about a year now and I'm planning on to hook it up...but now I'm in the process of Dropping it a 1.5' inch...do I need any alignment adjustment....will I lose my comfort as like my stock springs??????? </STRONG>
The ride is alitte rougher but its worth it because it looks awesome and handles great.
Originally posted by Rymnrsn:
<STRONG>
You will need an alignment after you drop the car. Wait a week or so before you get the alignment because the car needs to settle.
The ride is alitte rougher but its worth it because it looks awesome and handles great.</STRONG>
<STRONG>
The ride is a bit stiffer, but it'll feel just like stock after 2 or 3 days. You'll forget what the stock ride felt like and the steering will be tighter which I like more.
Hey was up,
I have the pro-kit on my cl for about 8 months now and I looked at the inside front tires and they are shreded badly! I even rotated my tires. I hope the make a front camber kit!
Originally posted by StypeCL:
<STRONG>Hey was up,
I have the pro-kit on my cl for about 8 months now and I looked at the inside front tires and they are shreded badly! I even rotated my tires. I hope the make a front camber kit!</STRONG>
<STRONG>Hey was up,
So did you get your car aligned or not? And if so, how much was the camber off by?
<STRONG>Hey was up,
<STRONG>Hey was up,
Originally posted by Rod:
[QB]
As far as waiting to get an alignment, I was told to get it done right away because the toe will be off immediately and any settling that eventually happens will be minimal.
[QB]
[QB]
[QB]
Originally posted by Pull_T:
<STRONG>
No, you should wait at least a week before gettind the alignment done, 2 or 3 would prolly be better. It's actually not so much the springs that need to settle, but the rest of the suspension (bushings, etc.)</STRONG>
<STRONG>
Originally posted by typeR:
<STRONG>...you know i did some thinking about that and well i could be off and i am by no means any expert...but wouldnt any settling only affect camber?????something that cant be adjusted anyway...so if im wrong LMK but if not i would say get alignement done right away</STRONG>
I feel lucky since my camber is ok after getting an alignment done recently. I was expecting to shell out $$ to have the camber issue fixed since I have such a large drop...
but luck won out
but luck won out
- daemonichris -
i think you're actually concerned with your camber adjustment. at 1.5 inches, you probably won't have to bother with a camber kit. as for alignment... no matter how much you lower your car, it will be off and you'll need to realign it.
Medinak12
09-23-2015 07:11 PM
