I'm an idiot
I'm an idiot
Today I replaced my windshield wiper linkage assembly because it was slamming down. Then I go on the forum and see that all I needed to replace was the plastic caps on the end of the linkages. I should know better as I usually check here first for everything - this site is an awesome resource. To add insult to injury, when I replaced it I originally indexed the motor wrong so up was down and down was REALLY down! LOL I got it straightened out of course and now it works like a charm. What should have taken 45 minutes took me a hour and a half. On the bright side I'm wiser because of it.
B A N N E D
normally the caps only come with the linkage itself, so not really replaceable seperate
how did you index the motor wrong???, you mean the wiper arms themselves???
btw: don't wipe the snow with your wipers after the car has been sitting, if you don't want it to break again
There is an arm that gets bolted down to the wiper motor and it has an arrow on it. I figured out the hard way that I should have matched the location of the arrow on the new linkage assembly. I ended up 180 degrees out and thus when the motor turned on for the first time, the blades went down the windshield instead of going up. It was easily fixed.
"DD" Designated Drinker
I did that about 2 months ago. the removal of the plastic cover was the tricky part...trying not to break anything.
but WHY THE HELL DONT THEY SELL THE CAPS THAT WEAR OUT??? 175$ compared to like maybe 5$.....
B A N N E D
so both of you bought part #10 :shakehead
at:http://www.hondapartsunlimited.com/i...NDSHIELD WIPER
normally you just replace part #11 or #12 (both of them include the neccesary white caps), don't kow what one of yours popped off (more then likely it looks like it would be #11), if it was #11, it is like $20
B A N N E D
so get out and actually manually brush the shit off your windshield, and don't expect the wipers to do everything
as long as you don't wipe the snow off that has accuminlated on the windshied from being parked for a peroid of time, they can easily last the life of the vehicle,
B A N N E D
i thought it was more because you put the motor's arm on backwards , but i guess i kinda misread it/misunderstood it a little , that you had replaced everything minus the motor itself
