ignition system help!
Old Apr 11, 2005 | 02:46 PM
typeR's Avatar
if you saw my previous thread about the CEL then here's where im at...added 3 gals of 108...no resolve...disconnected - power supply no resolution,dissconnected uni chip still no...where is the main unit sending signal to the coil packs?
Old Apr 11, 2005 | 03:02 PM
Smitty's Avatar
what other thread?
and what main unit?.. you talking about the ECU?.. you want to know what wires on the ECU?
Old Apr 11, 2005 | 03:29 PM
typeR's Avatar
Originally Posted by Smitty
what other thread?
the other thread that says CEL...any way i was thinking theres a main ignition controler...wonder where it is?
Old Apr 11, 2005 | 03:48 PM
allmotor_2000's Avatar
The worst-case is if Unichip somehow destroyed your coils...
Put everything back to stock... (ECU-wise) what happens?
Old Apr 11, 2005 | 04:07 PM
typeR's Avatar
did that no change...keep in mind the uni chips been in for 6 month + no issues
Old Apr 11, 2005 | 07:46 PM
typeR's Avatar
took all the iridium IK22's out and cleaned them...they had a build up of white ish alittle brown thick dust that was hard to get off this did not resolve the problem...i should add
the idles perfect and runs fine if not strong up until vtec then it just struggles badly to get to redline ...i pretty much cant even redline in second no noticable noises...there where 7 codes thrown random cylinder misfire all 6 and the last code was something like primary igniton or cylinder misfire
P1399
Acura604
20
Aug 5, 2017 12:55 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
h22lude
Sep 27, 2015 06:22 PM
