ignition system help!
if you saw my previous thread about the CEL then here's where im at...added 3 gals of 108...no resolve...disconnected - power supply no resolution,dissconnected uni chip still no...where is the main unit sending signal to the coil packs?
Originally Posted by Smitty
what other thread?
and what main unit?.. you talking about the ECU?.. you want to know what wires on the ECU?
Originally Posted by allmotor_2000
The worst-case is if Unichip somehow destroyed your coils...
Put everything back to stock... (ECU-wise) what happens?
took all the iridium IK22's out and cleaned them...they had a build up of white ish alittle brown thick dust that was hard to get off this did not resolve the problem...i should add
the idles perfect and runs fine if not strong up until vtec then it just struggles badly to get to redline ...i pretty much cant even redline in second no noticable noises...there where 7 codes thrown random cylinder misfire all 6 and the last code was something like primary igniton or cylinder misfire
P1399
P1399
Acura604
20
08-05-2017 12:55 AM
ExcelerateRep
10-14-2015 08:20 AM
