if you have a cai, does it become
'Cooter
kinda sorta...right there with u bud...my CAI suks in the hot weather...even at 5K, it's barely noticeable...got the auto-down problems...man, hot weather sux in this car
that's y i prefer cold weather to hot weather...heat works well, heated seats, and the CAI that totally rocks in VTEC land
'Cooter
Originally posted by JetSet:
<STRONG>what do you mean by auto-down problems? </STRONG>
'Cooter
Originally posted by cl-driver:
<STRONG>Yeah I can't imagine how hot the air must be under the hood. Hmmm...custom heat shield for the pipe...sounds like a project...</STRONG>
'Cooter
Originally posted by Closer:
<STRONG>Takes more power to run the A/C than it
gains by cooling the air.</STRONG>
Happy CL-S Pilot
I drove like 10-20 mins, I opened the CLS and I could not touch the my polished CAI, freking hot!!!!
However, on the other side, I touched the pipe just after the Cone filter and it was not warm or too warm!!!
The CAI will always get colder air than the OEM intake. As for temps and power...
Each 40º F increase in temp will kill about 6% of your power.
So, if the car is making 260 HP at 70ºF, then it will be making about 244 HP at 110ºF, and will make about 275 HP at 30ºF
The CAI's pipe will cool off as you drive off and different intakes with their different pipe coatings and compositions will heat-up and down at differing rates
Actually... the stock intake is well seperated from engine heat... so air to CAI isnt THAT much cooler in this type of weather situation.
The main advantage you see here is the increased filter area and smoother airflow...
If the weather was cooler.. CAI
Is there a way to wire up the fans to run???? thats an easy way to keep temps down at the track.
Originally posted by magnetic1:
<STRONG>
Is there a way to wire up the fans to run???? thats an easy way to keep temps down at the track.</STRONG>
<STRONG>
A Helms manual and a couple of relays would probably do the trick. The biggest headache would be figuring out where to drag the wires into the cabin and where to put the switch ot override the coolant fans
Location: Somewhere between here and there, yet neither.
The temp of your piping doesn't make a huge difference, just the outside temp...because of the velocity of the air being sucked in...it doesn't get a chance to get heated up by the piping....the physics or chem majors should know this.
Originally posted by moomaster_99:
<STRONG>The temp of your piping doesn't make a huge difference, just the outside temp...because of the velocity of the air being sucked in...it doesn't get a chance to get heated up by the piping....the physics or chem majors should know this.</STRONG>
So, in the case of the AEM, you’re probably right, but your are assuming a lot and assumptions are the mother of all fuck ups...
lanechanger
10-13-2015 10:56 AM
