If i lower, will i CAMBER???????
Old Feb 13, 2002 | 04:41 PM
ktgumbo's Avatar
Balla on a Budget
Hey guys i am thinking about lowering my 01 cl. I had a civic before this car and after i lowered it the front and the rear both cambered in and i had to buy kits for them. They tires really wore until i got them! IS this the same for the cl's! Or can i just lower them and not worry about them? Also how low should i go! some pix would be appreciated! Thanks kambiet@vct.net
Old Feb 13, 2002 | 04:44 PM
mcdanjw's Avatar
I had to do a rear camber kit.
Others claim not to need one, but I sure did.
Old Feb 13, 2002 | 08:09 PM
AztecRol's Avatar
The Screeching Toyo's
I just noticed that I have some inside tire wear on my car. I carry a lot of tools for work in the trunk, but I am gonna get the camber kit now.
Click on the link in my sig below to see pics of my car before and after.
Old Feb 13, 2002 | 08:28 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
You shouldnt need one for the Comptechs.. but if you go with anything lower, like Eibach or H&R, you will probably get some negative camber that wont align into spec w/o a kit
Old Feb 13, 2002 | 09:54 PM
ComptechType-S's Avatar
Time to POWER UP!!
Since our control arms are not adjustable you "will" need a camber kit. Some negative camber is "good" for the car (helps with cornering). Just remember, the lower the car, the more negative camber you will get. Eibach has a camber/alignment kit (part # 567090K) for about $160 (plus shipping). Thats less than the cost of 2 new tires
Old Feb 13, 2002 | 10:23 PM
synth19's Avatar
It all depends on how low you drop your car. If you are looking at comptech springs, no need for a camber kit. Just make sure you rotate your tires at least every 5-7k miles
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
