Idle Fluctuation With Engine Load
Old Jul 13, 2009 | 10:34 AM
civicdrivr's Avatar
As some of you may know, E30 and myself have installed the new 09 3.7l TL intake manifold on our car. His install went smoothly. Mine, well, it didnt.
At first everything was fine. Then I had a high idle after about 200miles on the setup. I checked for vacuum leaks and replaced the IACV with a brand new unit from Honda.
Right now the car will idle perfectly upon initial startup. However, once I put load on the engine (any load, from tapping the gas to turning the steering wheel) the idle will begin fluctuating between 1k and 2k rpms. I also get a CEL for code P0505, which is the Idle Control System.
Oddly enough, the power steering pressure switch is part of the idle control system. I visually inspected the switch and saw no defects.
Does anyone have any input on this or know of anything else for me to check?
Thanks in advance.
Old Jul 13, 2009 | 10:48 AM
Pseudomaniac's Avatar
If the mani is bolted up and seated properly and you've eliminated all vac leak possibility, it almost has to be a sensor issue.
I'd be most suspect of the MAP sensor since you've changed the dynamics of the manifodl, but I'm not certain that the logic that checks idle queries that sensor.
I do know that accessory sensors come into play with idle control - Air Conditioning / Power Steering, Vehicle Speed. Any leads stretched too far - bad connections?
Anytime I've had oddities like this, I pop all connectors open, hit em with the electronics cleaner aerosol, dry them, and then put anti-seizing compound where necessary and reconnect. It at least eliminates that as a factor, just sucks when the plastic connector teeth break on you....stupid dry-rotting plastic.
Old Jul 13, 2009 | 10:56 AM
civicdrivr's Avatar
The mani has been off and on numerous times to check for seating issues. Ive replaced all gaskets and checked the vacuum lines numerous times. The manifold isnt the issue. The MAP doesnt control idle, and if that were the issue Id be getting a different CEL.
None of wires are stretched. The only wiring I touched during the install is Intake Air Temp. The wires needed to be lengthened to reach the intake pipe. They arent shorting out either. They are heatshrinked and taped.
Im getting nervous while I keep looking at the troubleshooting steps for the PS pressure switch. Basically it goes check wires at ECU, if voltage is out of spec replace switch. Check wires at switch, if out of spec repair broken wire. If no broken wires try a new ECU.
Its that last part that has me worried
Old Jul 13, 2009 | 11:13 AM
The painful, but less painful than buying a new computer, step would be to see if it continues to do it with your old manifold back on there of course...
Old Jul 13, 2009 | 11:18 AM
civicdrivr's Avatar
Did that. Same deal
I even replaced the TB with my old one. It doesnt fix the idle issue. I think that if its doing it only when load is applied its definately an electrical problem.
Old Jul 13, 2009 | 11:51 AM
I agree with your logic - very odd. I'm sure you've checked this... Tried pulling the PCV out and blowing on it yet to see if it's holding properly? What about the little rubber boot around it leaking? - that one evaded me on my B20 Civic for a month....
Old Jul 13, 2009 | 11:54 AM
Here's the procedure from Honda.....
DTC P0505: Malfunction in Idle Control System
Start the engine. Hold the engine at 3,000 rpm with no load (in Park or neutral) until the radiator fan comes on, then let it idle.
Check the engine speed at idle with no-load conditions: headlights, blower fan, rear defogger, radiator fan, and air conditioner are not operating. Is the engine running at 750 ±50 rpm ?
YES - Intermittent failure, system is OK at this time.
NO - If the idle speed is less than 700 rpm , go to step 3; if it's 800 rpm or higher, go to step 4.
Disconnect the 3P connector from the IAC valve. Does the engine speed increase or fluctuate?
YES - Adjust the (base) idle speed. If it's impossible, clean the ports in the throttle body.
NO - Replace the IAC valve .
Turn the ignition switch OFF.
Remove the intake air duct from the throttle body.
Start the engine and let it idle.
Put your finger on the lower port (A) in the throttle body. Does the engine speed drop?
YES - Adjust the idle speed. If it's impossible, replace the IAC valve.
NO - Check for vacuum leaks. Make sure the throttle valve is completely closed, and repair as necessary.
Old Jul 13, 2009 | 01:01 PM
civicdrivr's Avatar
The PCV is brand new, however the seal around it is not. I dont have anything leaking from it though, but Ill still get a new seal. Did the rubber boot cause your idle to fluctuate like this?
YES
YES, the idle will raise to about 1500rpms and then if I adjust it, nothing happens. The ports are clean.
I did not do this yet.
I was speaking to a Honda tech and he said I have a very peculiar situation on my hands (not something I want to hear). He recommended checking all the gaskets one more time for any air leaking. He said that since the idle reacts when I turn the steering wheel, the sensor is still operational. Its still detecting a pressure change. Im going to reluctantly check for vacuum leaks once more.
Does anyone know of a way to test an IACV? I googled "Honda P0505" and everyone who had this code replaced the IACV. I installed a brand new one last week and the problem is still not resolved, but its possible that it is faulty.
Old Jul 13, 2009 | 01:08 PM
[QUOTE=civicdrivr;11099590]The PCV is brand new, however the seal around it is not. I dont have anything leaking from it though, but Ill still get a new seal. Did the rubber boot cause your idle to fluctuate like this?
QUOTE]
A split in that seal was the culprit for a surgey idle - but I was Hondata on that motor - and it doesnt care so much about the IACV range other than using it to regulate fuel for the idle.
Old Jul 13, 2009 | 01:11 PM
civicdrivr's Avatar
Ok. Its a $2 seal so Ill replace it anyway. It was an oversight when I ordered the PCV and didnt catch it till I installed it.
The more I think about it the more I keep looking at the IACV and saying that has to be the culprit. But at the same time the idle raised when I unplug it, so....
I dont fucking know anymore.
Old Jul 13, 2009 | 09:25 PM
civicdrivr's Avatar
I exchanged the IACV with another brand new one and the CEL went away, but I still have the idle issues.
Old Jul 16, 2009 | 12:26 AM
civicdrivr's Avatar
Theres something wrong with either the valve (doubt it) or the ECU. I checked the wiring and everything checks out fine. The IACV refuses to close. It stays open very slightly and causes my idle issues. Ill update this when/if I get it fixed.
Old Jul 16, 2009 | 08:57 PM
fuzzy02CLS's Avatar
Have you killed the battery & the backup fuse? Completely resetting the ECU? Then do the idle relearn.
Old Jul 16, 2009 | 10:03 PM
civicdrivr's Avatar
Ive reset the ecu and did the idle relearn more then 10 times. No matter what the IACV stays cracked open slightly.
I checked the wiring and everything tests fine. The last thing to test is the ECU. I need to find a 6MT ECU locally that I can use to test.
Old May 29, 2010 | 06:25 PM
Rajca's Avatar
wham bam thank you ma'am
im having someone of the same problem
was urs like this? and what did u do to fix the problem, need update
Old May 29, 2010 | 06:42 PM
friesm2000's Avatar
B A N N E D
see your thread
Old May 29, 2010 | 07:33 PM
Rajca's Avatar
replied. also did the relearn and didnt help at all
Old May 29, 2010 | 09:08 PM
civicdrivr's Avatar
This crack was the cause of my headaches:
Spray carb cleaner around the intake manifold and lower runners.
Old May 29, 2010 | 09:11 PM
Rajca's Avatar
will do that tomorrow
Old Jul 18, 2010 | 02:04 PM
AcuraGman's Avatar
Did you ever find what was causing your idle problem? I'm having the same issue.
Old Jul 18, 2010 | 03:17 PM
Rajca's Avatar
runner was cracked from over tightening the corner bolt. its in my build thread.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
IlliniAcura
Sep 19, 2015 09:31 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
