i smell gas!!!
Old Feb 9, 2003 | 03:07 PM
types1967's Avatar
i smell gas!!!
i smell gas when the car is in neutral while reving it a few times and the the blower is on in the car.should i smell gas at all or is it normal while the fan is on in the car while i sit there while reving the motor a few times?
Old Feb 9, 2003 | 06:13 PM
ChucksTL_RENAMED's Avatar
Get that checked out quickly as leaking fuel can ignite and you don't want that!
Old Feb 9, 2003 | 06:29 PM
LiQiCE's Avatar
Liquid Ice
That happens to me when I'm parked in my garage (with the garage door open) and letting the car idle for awhile while it warms up. I get a faint smell of gas coming in through the vents. (Not revving the engine at all) ... If you're outside you really shouldn't smell anything, but in an enclosed area you very well could ... esp. if you're revving it.
Old Feb 9, 2003 | 10:15 PM
BC's Avatar
BC
nearsighted visionary
Don't sound good too me. Put some baby powder at any fuel line joint or gasket seam. Run car, check spots.
Old Feb 9, 2003 | 11:18 PM
allmotor_2000's Avatar
You shouldn't smell gas.. period!!
(1) Check the fuel lines (hard lines) from under the car to the connection at the firewall.
(2) Check the high-pressure hose from the firewall connection to the FPR
(3) Check the high-pressure hose from the FPR to the rail
(4) Check the fuel-pump inlet and return connections. This is in the trunk... and these are plastic!!
Old Feb 11, 2003 | 12:03 AM
KavexTrax's Avatar
on startup, before the engine reaches operating temp.,
I don't exactly smell gas, but a faint exhaust kind of odor through the vents.
I thought that it would take a while before the cat convertor would start working (which is when the engine reaches operating temp.).
And at startup the engine would run on a rich setting? and then adjust to a more leaner one, thus emissions would be curtailed after that with the combination of the cat convertor kicking in too to reduce NO2.
Tech geeks feel free to correct me.
xsilverhawkx
Oct 5, 2015 11:00 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
