I need a shift knob!
The leather on mine from the facotry is peeling away. I really like the TLS6 knob but how hard is it to transfer that on, and how expensive? Anyone else get a good smooth shift from a particular knob that's not like $100?
brokslouky (01-07-2012)
The s2k & nsx are not a direct fit. You will have to make it fit & then figure a way to keep the boot up. I had a s2k knob on my car but had to drill a hole to mount a set screw to secure it to the shaft, then invert the top of the boot & secure that with a washer for the boot to stay up.
I have better solution. I've had s2k skunk knob and all i had to do was to find a proper washer or nut that matches the shifter thread screw it all the way down put that washer on top of it and then put that boot back and screw the knob down thats all its 5 min job maybe less. My s2k skunk knob came with a nut i think.
shifting at 7k
Pretty cheap, $30 from OEMAcuraParts:
http://www.oemacuraparts.com/acura/k...5-a01za-acura/
brokslouky (01-11-2012)
Quote:
Originally Posted by brokslouky
How much are those tls6 knobs? They are the best looking ones out there, personally.
Part#: 54102-TK5-A01ZA
http://www.oemacuraparts.com/acura/k...p-a01za-acura/
brokslouky (01-14-2012)
Here is another option. I just saw this on Craigslist. Might want to call and see if he still has it. I bought an aftermarket that has 1-6 and R on it when my leather started to peel. Good luck.
http://tulsa.craigslist.org/pts/2745344863.html
shifting at 7k
For those that did the S2K knob, could you break it down in more detail please? I got one myself, would like to put it in. I was contemplating getting this: http://www.ebay.ca/itm/Honda-Acura-S...-/260481063687
Would that fit on our cars?
Whats up with RDX owners?
Shift faster
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
Recently turned 18
I have the stock S2K knob and it's not an issue until the summer. That top metal part was hot as sh!t in the summer in Texas. It doesn't bother me so far in the cold here. Been as low as 25 degrees. I think mostly I just want to switch up the look for awhile. Makes me feel like the car is new.
Theres a lock nut that should go on the shifter below the knob, not sure if its there for the stock knob though. It makes it much easier to align it and the knob will never rotate on you.
8th Gear
There is a lock nut on the stock S2k knob part# 90310-ST7-Z00 and it's black chrome looking. List price is $1.90
Yep, thats what I have on mine:
![](http://i23.photobucket.com/albums/b378/civicdrivr/2003%20Acura%20CL/DSC02791.jpg)
You can just barely see it in that pic. It may be black when you buy it, but the moment you touch it with a wrench it gets scuffed. Maybe brass wrenches wouldnt scuff it if you really care about the way it looks - I didnt.
Recently turned 18
I like the way that lock nut gizmo looks Civic, is that one or two pieces? I have the perforated leather version as far as the knob. Your damn center console looks new, including the shift boot. Not fair.
Its two pieces - the lock nut and the boot holder(?) that came with the PSpec shifter. The boot was replaced 4 years ago, although it didnt need to be. Because of the knob I ran before this one, the perf leather didnt match so I swapped it.
Also, 303 Protectant FTW.
