I need clarification. No spark plug wires?
Someday pigs WILL fly!
I just read a post that says we have no spark plug wires! I have not looked for myself as the plastic shroud is too intimidating. Is this correct? How do it get spark? ![](http://www.acura-cl.com/ubb/confused.gif)
01 CL-S NightHawk Black/Ebony Bowling Ball Interior
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
<font face="Verdana, Arial" size="2">Originally posted by gto2050:
I just read a post that says we have no spark plug wires! I have not looked for myself as the plastic shroud is too intimidating. Is this correct? How do it get spark?![](http://www.acura-cl.com/ubb/confused.gif)
</font>
</font>
"the needle got buried at 140.....1,500 RPM later...the tach got buried"
pays to be young and crazy
99 3.0 CL
55 Chevy Suburban (chopped, dropped, tubbed and FLAME RETARDENT!!)
58 Eldorado Biarritz
just for those who don't know (tw1112) there are no plug wires on the Type-S. A coil pack sits on top of each spark plugs, there by eliminating the need. It's called DIS, Distrbutorless Ignition System. No carbs either ; )
99 3.0 CL
55 Chevy Suburban (chopped, dropped, tubbed and FLAME RETARDENT!!)![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
99 3.0 CL
I knew about the carbs but was unaware of the spark sitch.... tnx.
Yes, it is DIS, but that doesn't mean there needs to be a coil-on-plug install. DIS ignitions have been used for years with normally one coil pack between two cylinders, wasted spark method.
However, the coil-on-plug implementation is reletively new for wide OEM use.
As for upgrading them, really is no need. These are firing much hotter sparks already than what could ever be needed.
Actually there is a spark plug wire it just happens to be only about an inch or two long.It connects the coil pack to the spark plug.There is no need to upgrade your ignition system unless you are planning to go with forced induction or otherwise heavily modify your car.
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
