I lost my mojo... I mean V-tec.
Old Feb 1, 2003 | 07:03 AM
rondog's Avatar
Former Sponsor
Well, I've noticed that My Vtec is virtually gone since my new tranny was installed. When I'm increasing in speed, its too linear without the extra pull in the Higher rpm's. I have since installed OBX headers and still no Vtec. I don't know if the new torque converter or tranny have anything to do with it or if there is something else wrong with the car. I also have a low howl at idle since I removed the resonator from the stock intake. Maybe the fuel to air mixture is off? I've heard other cars without the resonator and my car sounds a whole lot different. With the addition of headers, I have alot more torque down low and immediete throttle responce, but up top, there is no difference than stock. me and lou were doing some comparrison runs aroundf were I live and we were very close, too close. With almost no traction we managed to run neck and neck as I started to pull slightly towards the end of 100mph+. Maybe his lightweight wheels allowed him to keep up? i just need my Vtec back, any suggestions?
Old Feb 1, 2003 | 07:07 AM
Zapata's Avatar
Cost Drivers!!!!
Take it to PAA.
Old Feb 1, 2003 | 07:16 AM
rondog's Avatar
Former Sponsor
why PAA? I took it there once and they kinda messed up my intake installation, not big deal but i seriously don't want to drive down to jersey and come back with a big ? and a ticket from the highway patrol.
by the way, I installed a short ram one time and drove with it for 2 days without reseting the ecu. then I couldn't take the low howl or ufo noice associated with it so I reverted back to the stock. the car had the same symptoms it has now. So I reset the ecu and them car went back to normal. this time around, i reset the ecu and didn't notice any difference.
Old Feb 1, 2003 | 07:44 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
A new tranny installation? Did you get a new ECU too?
If so, I suspect that Acura sneaked a "detuning" somewhow in the new ECU... Hit the dyno and get a graph... Did you check if your IMRC is working?
Old Feb 1, 2003 | 08:11 AM
lou_RENAMED's Avatar
yep i agree ... Rondog's engine has the power but I think that the new tranny feels less aggresive. My car at Vtec feels like it pulls more than Rondog's but it is only cause of the tranny.
O and Rondog nice runs I had a blast and that really helped me to make my decision. We will see what happens when I get my Comptechs. We'll talk about it at the meet later today.
Old Feb 1, 2003 | 09:23 AM
Scrib's Avatar
Administrator Alumnus
My new tranny was installed two days ago and my car still pulls like a mother humper. Sounds like it's something else.
Old Feb 1, 2003 | 10:12 AM
Nicky Pass's Avatar
Fuct in the hed!
What about the V-TECH controll valve????
Old Feb 1, 2003 | 10:48 AM
ruvz's Avatar
YOOOOOOOOOOOOOO!
Most likely it is the MIRC valve... your turn has come..
Old Feb 1, 2003 | 10:51 AM
Scooter's Avatar
'Cooter
and that's an easy fix under warranty yadda yadda yadda
Old Feb 1, 2003 | 11:16 AM
4thGSi's Avatar
STi
I heard vtec will not engaged if your oil is low..
Old Feb 1, 2003 | 03:14 PM
langjae's Avatar
do it yourself, !
Hey ron..my shit does the same thing. It's been like tihs since the summer for me. Seems that you gas it and it just slwoly creeps and doesn't down shift for the quick "thrust." I'm thinking its the MIRC thing. Haven't checked it as I have no been in NY for quite sometime. Let us know how it goes.
Old Feb 1, 2003 | 03:51 PM
scalbert's Avatar
Just a quick correction, it is IMRC...
Old Feb 2, 2003 | 09:29 AM
rondog's Avatar
Former Sponsor
and how do get the dealer to fix it/ i took the car to the dealer and they did a diagnosrtic check but nothing came up in the comp. Is there a way i can fix it or see if that is the cause myself?
Old Feb 2, 2003 | 09:33 AM
Python2121's Avatar
The hair says it all
I dont know the problem, but heres an educated guess:
When my brother put on a CAI on his integra, it was idling at some crazy RPM. We pulled the battery or the fuses, i dont remember which (does the same thing anyhow) and let it sit for a while. We put everything back and then started it and i guess the ECU fixed itself. Could it be a similar problem (obviously not same simptoms)?
Old Feb 2, 2003 | 10:45 AM
Scooter's Avatar
'Cooter
OMG, there's no equipment u need...just throttle it to 3800RPMS...if u don't see the switch pop up, then it don't work...it's under warranty...VERY easy
Old Feb 2, 2003 | 08:59 PM
darrinb's Avatar
///M POWER
proly the acutator, is that anther word for imrc??
Old Feb 2, 2003 | 09:04 PM
rondog's Avatar
Former Sponsor
damn, since the tranny gat replaced, its been like this, bout a month. I have to go all the way to PAA to get this fixed if thats the case. Gonna check tommorow with bigman to see if thats the case. how long is the fix take, is there an adjustment or a repalcement for the part?
Old Feb 3, 2003 | 12:19 AM
rondog's Avatar
Former Sponsor
i saw the actuator and yes, it did open at the higher rpm's. I really don't know what it is that is causing my car to act sluggish when it is in V-TEC, feels like there is no power up there. there is also a mumming noise at idle since I took out the intake resonator. I'm baffled and curry acura already diagnosed my car with nothing wrong with it. DAMN.
Old Feb 3, 2003 | 06:29 AM
Scooter's Avatar
'Cooter
any slack in throttle wire???
Old Feb 3, 2003 | 07:56 AM
scalbert's Avatar
I know it suxs to have to outlay the money, but I would strap it on a dyno to get some numbers. The plot can often show quite a bit of information.
Old Feb 3, 2003 | 09:13 AM
rondog's Avatar
Former Sponsor
no slack in the throttle, I mean the engine just wails and the car is extremely responsive down low, its just the power doesn't match the engine scream up top, like there is soething missing. I would dyno it but there are no dynos in the Yonkers or 5 burough area that i know of. any suggestions?
Old Feb 3, 2003 | 09:42 AM
Scooter's Avatar
'Cooter
i think there's 1 place left out on Long Island...some Mustang dyno in Dix Hills area (which is out east a ways from me)
is it possible that even tho the actuator seems to b working, the butterfly valve is still not opening??? u need to crack open the engine to check that out unfortunately
Old Feb 3, 2003 | 09:51 AM
Shawn S's Avatar
With the engine OFF and preferably COLD you can move the actuator shaft with your finger.
If operating properly you can hear the plate click open inside the plenum.
If it doesn’t sound right then you need to pop the top off and check, which isn’t too hard.
Shawn S
scalbert's Avatar
The cable could be unhooked. But I wouldn't classify it as cracking open the engine...
You just remove the plenum cover and the upper plenum plate. There are no fluid passages here so it really isn't too different than messing with an intake.
Old Feb 3, 2003 | 04:47 PM
rondog's Avatar
Former Sponsor
I think i'm gonna just take the sucker to PAA andhope they will understand the dilemna. I feel kinda down when my car isn't performing at its best. thanks for the feedback.
Old Feb 3, 2003 | 05:33 PM
Hey Rondog don't feel so bad Im getting the 03' tails so next time I beat you and put my hazards on you'll be seeing white corners instead of red
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
