I had a scare...
Honkey
I had a scare...
I did some modifications to my trunk floor, and added about 150 lbs worth of hydraulic pumps. Shortly after I noticed what appeared to be a buckle in the body, right below the back of the rear-side windows. If you guys stand back and look closely do you have a ripple in the body here too?? PLEASE SAY YOU DO!
Aaron
Aaron
Honkey
there is a wave in the body..like a out "outy" door ding that's about 8 inches long going down the body right below the bottom rear quarter of the window. Thanks for your help.
A vertical one? No.
A thin design indent that goes horizontal down the side of the car right below the windows and to the back of the car? Yes.
Wheel wells bulge out slightly? Yes.
Odd bulges? No.
-J
Odd bulges? No.
-J
Aaron, yeah if I look *very* closely on my car, there is a slight ripple. It's apparent as a slight vertical optical distortion when viewed at an angle from the rear, positioned directly under the end of the rear quarter panel window. It's *very* small but is apparent on the top part of the quarter panels.
Honkey
Thank goodness you have the same thing, Fred. I think I'll run by the dealership to look at the cars there as well. Thanks for taking the time to look.
