How to remove front dash panel (for V1 install)
Old Jul 16, 2001 | 11:54 PM
fast_daddy_car's Avatar
I found a great place for the V1 remote display. Tucked under the dash visor, just above the "key" symbol in the right side gauge cluster.
I don't have a digicam, so here is a drawing:
O-O-O
The remote is where the "+" is. I put some sticky putty on the top of the remote and stuck it just under the dash visor.
I just now need to hide the cable. Since the center air vent is right there, I could snake it through, but it looks solid and no place to get it behind the dash.
If I could pop out the dash panel a bit, I could snake it through that way.
How easy is the main dash panel to remove. More importantly, how easy is it to put back together??
Thanks!
Old Jul 17, 2001 | 12:01 AM
MikeS 18's Avatar
Adult Supervision
Either Astro or Webtoker (I think) had their dash off...check really old posts or ask one of them directly.
Old Jul 17, 2001 | 12:23 AM
I found webtokers pics: http://www.acura-cl.com/cgi-bin/ulti...c&f=1&t=001968
Looks like once I get the front cover off I can easily run the wire the way I want to.
I can go through the vent, and between where the vent outlet meets up with the dash cover.
The question is, how does the front cover come off? There are 2 top screws, is that it and just pulls to the front? Are there any sneaky plastic tabs that will go snap when I do this?
thanks!
[ 07-16-2001: Message edited by: fast_daddy_car ]
Old Jul 17, 2001 | 12:53 AM
davematthews-CL-S's Avatar
can you find a digicam and post pics please.
Old Jul 17, 2001 | 11:12 PM
up.
Are there just the 2 top screws, then pop it off?
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
james357
Feb 13, 2016 02:37 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
