How much variance is acceptable in load/rate test on Comptech springs???
Old Mar 22, 2002 | 08:46 PM
BBsAcuraRacing's Avatar
MIne are as follows:
Front load / rate
1299.5@7.600in / 253.7 lbs/In
and
1342.5@7600 in / 256.1 lbs/in
Rears
637.8@9.38 in / 200.6 s/in
610.4@9.38in /194.4 lbs/in
Is this an accepable match???
Old Mar 22, 2002 | 08:58 PM
EricL's Avatar
A question for a question:
Didn't they put front-driver, front-passenger, rear-driver, and rear-passenger tags (or equivalents) on the springs?
The weight is not exactly the same from left-to-right and visa-versa.
And you asked an interesting question -- since I wonder how much the variation would impact some "tight tire and wheel fits" when lowered...
Old Mar 22, 2002 | 09:07 PM
I should read before I write.
The paper says install spring with higher spring load/rate installed on the drivers side.
I guess that makes sense since 1 person is mostly in drivers posittion...
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
Froid
Sep 27, 2015 06:16 PM
