How much does a side mirror cost?
Above n Beyond
Some drunk idiot decided to take a swing at my car while I was driving down a side street and connected. My mirror is still attached but only by the wires.
Can it be fixed?
If not, how much do they usually run?
Can it be fixed?
Above n Beyond
Originally Posted by nbennettksu
tht sucks man, in my experience at the dealership, a mirror hanging on by the wires has to be replaced.
by the way, above and beyonds pretty good
Originally Posted by CL-Future
Sorry to hear that Jim, here are some prices...
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Looks like about $188 for the side mirror.
Can it be fixed?
Can it be fixed?
Above n Beyond
Does anyone know if the actual block mirror can be separated from the part that is connected to the window? My actual mirror and housing is fine, but the triangular piece that is connected to the car is what's cracked.
Also, how hard is it to install? Anyone know if the wire harness is just plug n play?
666 Speed
1 Post
I'm pretty sure that if you take off the triangular panel where the tweater is, you should see the 3 nuts holding on the mirror and the wiring harness in the middle. You pull that out and the 3 nuts and and squeeze the connector and the mirror pops right out.
Thats at least how it was on my first gen. I didnt have a need to rip apart my door panel yet on this one. (knock on wood)
Above n Beyond
You'll see here that the red arrow shows the part connected to the car. That is what I need replaced.
The blue is the actual block mirror that is not affected.
The green is where the crack actually is.
Can the red piece just be replaced?
![](http://i120.photobucket.com/albums/o185/unc0808/untitled.jpg)
What to do, what to think
.....you gotta get the whole housing...sorri....its plug and play harness. just remove the the door panel for access and two 10mm bolts holds the housing. I replaced my neighbors 07 TLS driver side not hard at all
lol....trying to help jim.....oh yeah btw how was your b-day that night sorry I couldn't make it I was caught up with some things that night
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
