how many pistons is stock front caliper
Busy Living
searched a bit and doesn't seem like we got a definite answer.
It appears the AV6'rs have a single piston, but are able to upgrade to a a dual compliments of an NSX or Legend.
I Can't imagine us only have 1 piston front calipers, but it wouldn't be the first time Acura suprised me.
Busy Living
it's true... i've found 3 people saying the stock CL caliper is a single piston...
I see no reason that we can't do the same upgrade that the AV6's are doing...
sounds like for $120 we can new dual piston Legend calipers.
The legend calipers also seem to be more desired since one of the piston's is larger then on NSX.
Doin' da crack shuffle
what do you think about this swap Jens?
Busy Living
A TL caliper piston (assuming 45mm diameter) has a piston surface area of 1590 sq mm. The Legend caliper pistons have a TOTAL surface area of 2512 sq mm (40mm x 2) (158% more) and 2267 sq mm (38mm x 2) (143% more) while the NSX calipers have a TOTAL surface area of 2034 mm (36 mm X 2) (128% more).
Jens
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
