How does dynamat effect exhaust noise?
Those with dynamat or some type of sound dampning in the trunk, how does it effect the exhaust in the cabin?
im getting tired of the drone noise from the comptech exhaust i was thinking maybe covering the bottom of the trunk with dynamat and maybe under the rear seats too.
do you think this will help block out some off the exhaust noise?
sidemarker
sidemarker
yes...especially the rear fenderwell area this is where most of the cabin noise comes from.but at the same time you might get the inserts that comptech sells...
but since lowering my car theres a little bit more of road noise and i also plan on getting some subs so i figure i could kill two birds with one stone by just using dynamat instead...
sidemarker
do it yourself, !
Yea just line your trunk..take out the back seats and back panels and line all that. But don't use dynamat..its kind of a ripoff. Use like raamat..thats what i use and its so easy to put on. Roof felt works for under oyur seats real well--u can get that from home dept..but its a bit hard. Theres these other brands like brown bread and b-quiet bu they're kinda expensive. oh and cascade..but never used that either :p
do it yourself, !
Originally posted by oce01acura32cl
dynomat is a rip off? i thought it was the best???
Comptech's a ripoff..but too bad there's no cheaper equivalent alternative. But dynamat by far isn't the best/only tihng out there.
www.cascadeaudio.com
plus dynamat is thick and heavy. these guys make deadening materials that are thinner, lighter and have better adhesion.
the last one alive
There are lots of alternatives to Dynamat. I had Accumat by Scosche on my Accord a few years back. It stayed put A LOT better than Dynamat. Stinger also has some sound deadening products. rec.audio.car is a good newsgroup to check out (via google if you don't have a newsgroup server). I know there are like half a dozen or so companies at least that make this kind of stuff. Dynamat just happens to market towards car audio enthusiasts, which = $$
My Home Planet
There's also some stuff called "gator skin" or something like that. It actually works better than dynomat and is cheaper. I'm not sure where to get it though. It looks like asphalt in a thick paper.
Received 1,080 Likes
Cascade is by far the best. I did my whole trunk, rear deck, trunk lid and door panels. The stuff sticks like crazy. And, BEST OF ALL.....
It doesn't have any odor. Dynamat stinks.
BTW, this will do nothing to reduce the drone from the Comptech exhaust. The quiet tips get rid of the drone altogether. Sounds almost like stock, except at WOT.
Find beauty in dissonance
Originally posted by Bluto
Is dynamat that bad? I checked it out in a store, did not smell like much. Is newer dynamat different? Or does it take heat to cause the odor?
i thought i might
maybe i should get the quiet tips inserts...
sidemarker
Originally posted by Ken Schwartz
I agree. If the sound bothers you that much, why not get the quiet tip inserts instead of going through all that?
plus i mentioned earlier that i might get some subs so i figure the sound dampening will hope in both cases...
sidemarker
dainmezron
10-16-2015 06:56 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 09:00 PM
