How does the CAI bypass valve work????
I have been watching Xephyr2K's CAI progress and I have a ?????
After seeing the bypass valve, I have to ask, How does it work?
If the bypass valve is just a little filter then won't the engine pull some air from the engine compartment during a normal situation?
South Jersey: 2001 Acura CL-s Gold with navi/spoiler/splashguards/V1/w/cdu
stock 1/4 mile 14.698sec@95.91mph
Atco Raceway 12/1/00
rdsandy,
Well no, the valve is just an extra filter, however, it has rubber flaps that seal it air tight under normal driving. In the event that you submerge the filter in water a vacuum of ~15psi+ would build and the intake would attempt to draw water up the length of the induction tube, however the valves flaps open and equalize the vacuum and prevents the water from rising. Hope this helps
Chris Koncur
Xephyr Performance C.A.I.
2001 Nighthawk Black CLS Type S - Xephyr Performance Cold Air Intake, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, Best GTECH Sprint 6.05 Xephyr Performance Intakes
Chris Koncur
X,
Thanks, yes this answers my question.
If I take a ride to cherry hill, can I pick one up? I'm about 30 minutes from CH. Thanks.
sockr1
10-01-2015 01:31 AM
