How do you do a burnout???
Old 03-27-2001 | 02:58 AM
M5 Lite's Avatar
Hey guys,
How do you do a burnout on a RWD car? How about a FWD car? Any problems this causes in the long run?
'98 Dakar Yellow ///M3
www.BMWExperience.com
Forums are now open at www.BMWExperience.com
Old 03-27-2001 | 09:11 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
RWD....step on the brake and floor it. FWD is a little trickier....you have to spin the motor pretty high to induce wheel slip (remember to have the Parking brake on) and you have to feather the clutch.
2001 Cl-S Black on Black with Navigation
Black Tint all around (15%~45%)
Weapon-R Dragon Filter
Weapon-R Coil-Overs
Koni Adjustable Struts
Comptech Sway Bars
(sooner than I thought...)
Comptech Headers
Old 03-27-2001 | 09:27 PM
volsfan0911's Avatar
Doing e-brake burnouts on a front-driver isn't great for the rear brakes, but it will work. RWD simply involves putting down more power than the tires will hook up to the pavement. In my case, that involves disabling AH (active handling) and stepping on the gas!
when you're ready to succeed!
Old 03-28-2001 | 03:43 AM
Gs400TRD's Avatar
<font face="Verdana, Arial" size="2">Originally posted by M3Sins:
Hey guys,
</font>
make sure the traction control is off...in your m3 it easy as F**K get the tach up to about 2100,,,then drop it into first and then floor it!!!...try not to hold on the brakes good way to warp rotors. (Especially in RWD) you should be able to light the tires for a good 5-10 seconds. FWD same concept, works better on a slight incline though...especially if the car roll back a bit in Idle.
BUT NEVER PUT IT IN NEUTRAL AND REV AN AUTOMATIC THEN DROP IT INTO DRIVE!!! GREAT way to drop the transmission.
Gs400-TRd
Old 03-28-2001 | 04:05 PM
jpgolf14's Avatar
In the CL-S all you have to do is turn VSA off and floor it. It doesn't hurt if there are stones under the tires also to induce slippage.
2001 red cl type s, no navi, black interior, wing, mudflaps, purchased, 12-00
Old 03-29-2001 | 03:54 PM
M5 Lite's Avatar
I am looking for a standing burnout, not a tire spin to get to 60. Just a standing burn out that I see with lots of smoke coming from the tires. Do you hold down the brake completely or lightly?
Old 03-29-2001 | 10:01 PM
Jeckle and Hyde's Avatar
work from 7am to 10 pm every day, 7 days a week. then be sure to have fights with the neibors and friends. repeat this for 3 years without mental support!
thats how you get or do a good burnout
Old 03-30-2001 | 03:34 PM
frederix's Avatar
</font>
I'm not sure what the best rpm is for the M3 so you'll have to play around with it but 4,000 rpm should be sufficient. You shouldn't have to use the e-brake. Just put it in 1st, rev the engine, and pop the clutch. The higher you rev it, the more wheelspin you will get. Just don't redline the engine and pop the clutch. The only car that I know of that can survive that is a Porsche 911 Turbo S.
Old 03-30-2001 | 03:44 PM
eclipse23's Avatar
Moderator Alumnus
Well I usually offer her pot, then bang her.
That's how you do a burnout.
01' Acura CL Type-S
Piaa 19169 Bulbs
Valentine1 Pig Detector
XEPHYR CAI In 3 Days
01'Acura Integra GSR
NY NJ PA ACURA MEET LOCATION:
http://www.marriotthotels.com/dpp/PropertyPage.asp?MarshaCode=EWRHO
2:00pm be there or be lame
Old 03-30-2001 | 07:21 PM
MCHM3's Avatar
magnet
lmao
2001 cl type s,custom voltage blue paint job, comptech headers, 18 inch ssr agle strusse rims(painted voltage blue with chrome lip), greddy evo exhaust, cross drilled rotors, pioneer avx 7000 tv, playstation2, iceman cold air intake(custom)nos fuel pressure regulator, piaa ion yellow fog lights, slammed on nex suspension (level ten torque converter and b&m tranny cooler)3.5 litre upgrade on april 16!(dommed topped pistons, mdx crankshaft, rods , bearings, heads ported and polished, vtec timing
my old car www.hondatech.org/99acv6ic.html
my cl-s
http://albums.photopoint.com/j/AlbumIndex?u=1364953&a=11597233
Old 04-03-2001 | 06:40 PM
al9rr's Avatar
Hold the brake just enough to stop the car from pulling. Don't mash it, wear out rear brakes. I usually have some windshield liquid in the trunk so I pour some over the rear wheels to get it nice and slippery. On a FWD car I just step on or pull up the ebrake and floor it.
2001 CL Type S Fast
1993 Mazda RX7 Faster
1999 Honda CBR900rr Fastest
Old 04-04-2001 | 01:44 AM
M5 Lite's Avatar
The Ebrake locks up only one set of wheels??
Old 04-04-2001 | 12:58 PM
al9rr's Avatar
</font>
On a Front Wheel Drive car it will lock up the rear wheels.
2001 CL Type S Fast
Old 04-04-2001 | 09:07 PM
HAHAHAHA...you didn't know that!?! I thought you knew so much about cars M3??? Hmmmm....makes me wonder about you!?!
</font>
Weapon-R Coil-Overs
Comptech Sway Bars
Comptech Headers
Old 04-04-2001 | 11:21 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Smoke alot of weed and u will be a burnout!
Old 04-05-2001 | 03:28 AM
M5 Lite's Avatar
<font face="Verdana, Arial" size="2">Originally posted by moomaster_99:
</font>
Im not big on burning tires and pro racing on the street. I drive the car because its a great sports car. I know about BMWs in general. I don't know much about the technical aspects of it. Thats why I'm asking guys like you these questions. I help you in my field of expertise and you help me in yours (technical).
Old 04-08-2001 | 04:28 AM
key master's Avatar
6th Gear
Hmmm.. I thought bimmers were all RWD? If so, no need to activate your e-brake. Hold down your brakes 80% and floor it. Be sure not to hit the rev limiter during all of this... not good for your engine!!
http://www.shadowscove.com/kmaster/z...ck-burnout.jpg
WORKS FOR ME!
-Jim
[This message has been edited by key master (edited 04-08-2001).]
Old 04-16-2001 | 08:59 PM
Closer's Avatar
Pour ammonia on your tires.
You'll have the whole block covered in a
mushroom cloud of disgusting white smoke and rubber.
Half an hour later you'll still have smoke
coming out of your trunk and hood.
Great fun.
Old 04-17-2001 | 02:42 AM
Iridium130's Avatar
w.t.f., mate?
<font face="Verdana, Arial" size="2">Originally posted by Closer:
Great fun.
</font>
Wtf?
~Phil~!
2K1 satin silver CL-S since 6/13/00 named Laetitia! ~#10,029!!~ ~Navi!~ ~XEPHYR PERFORMANCE CAI~ ~Quantum tint~ ~Hiper Hibrid Plasma Xenon road lamps AND high-beams~ ~spoiler, baby!!~ ~Uniden LRD 6599SWS Radar Detector~ ~Shine by Meguiar's Gold Wax~ ~Member of the Scratched Rims Club~ ~Getting a red Acura badge shortly.~
Former post count : Over 500!! FREAK!
Old 04-17-2001 | 06:08 AM
prikid's Avatar
find a hill ... face the car uphill... and then floor it .
In my CLS I could do this when I put it in neutral, accelerated a bit and then shifted to D5.
Smooooooooookin'
'01 CL type-S.
Stats on all-stock with 1/2 tank:
0-60 in 5.85
Why drink and drive, when you can smoke and fly?
Old 04-19-2001 | 07:44 PM
yezbozz's Avatar
<font face="Verdana, Arial" size="2">Originally posted by prikid:
Smooooooooookin'
</font>
hahahah
rolf
dunno if your kiddin or not, but that'll make for a good aggie joke.
2001 cls: silver/black;spoiler;mud guards
future mods : headers;intake;exhaust;springs
CheeseyPoofs McNut
10-11-2015 12:25 PM
CLpower
05-11-2006 09:37 PM
rise
Console & Computer Gaming
27
01-21-2005 05:07 PM
