How come?
How come?
I might be on an island here, but it makes sense to me that in order to up shift while accelerating hard, you'd want the shift to be the same direction as the pull and vice versa to downshift.
I did a couple of keyword searches in the forum and as soon as you start talking transmission, you get ALL THOSE threads.
Has anyone successfully reversed the shifting to when you pull back it upshifts and push forward to downshift?
I guess he means when you want to accelerate, ur body motion tends to move back and thus upshifting should be backward instead of forward. While when u braking, ur body moving forward, so downshifting should be upward.
Am I correct?
Am I correct?
wtf...that makes no sense...and uhh...i think the car shifts perfectly the way it shifts now...but i dunno...that shift sounds too complicated to do on your car and why...dont like to move you hand up instead of down and vice versa?
OHHH wait a minute :idea: you must be talking about the sports shift....i have a 6spd....so disregard my comment....
i see what your saying...but still would be awkward...never thought about it that way tho...
i guess the trip tronic is trying to be just like a 6spd..even though it goes to 5spd...but in the 6spd the lowest gears are on top of the gear box...and the highest at the bottom so maybe thats why they did it that way...
1 top
2 bottom
3 top
4 bottom
5 top
6 bottom....pretty much all the higher gears on the bottom....
now do i make sense...prob not..
1 top
2 bottom
3 top
4 bottom
5 top
If your talking about in SS mode, I didnt like the way it was and i switched the wires around to make the + and - reversed. Its very easy and just 2 wired to repin or cut and switch around
these are just 2 the wires to switch
Originally Posted by VinceBlkCLS
I don't get it so did you just reversed so it would feel different and what chage would it make just shifting is different SS.
I preferred to pull back to up shift and push forward to down shift. Especially on track days
Am I correct?
Am I correct?
Precisely.
How difficult is it to get to? How do you "repin" it? special tools or your standard radio shack stuff?
You just have to remove the center console like you would to remove teh radio (you just need to get to the shifter on teh drivers side where the plug in harness is.
As to repin, its very easy. You just need something like a dentist pick (you can get similar tools at radio shack) and just look for the little tab inside the harness, lift up on it and pull the wire out.
Originally Posted by mystikk
WHOA that is pretty cool, I thought it took a lot more in-depth honkydookery to do that switch.
FAQ-worthy, maybe?
FAQ-worthy, maybe?
Originally Posted by CL6
Nice mod! You may even come close to 6 speed 0-60 times now!
Originally Posted by All Mine
Just making sure... But those would be the same wires that our auto's need changed? I'm planning on doing this today, so I'd like to know fo sho.
Well, mine's only a year newer than yours. But do the P's and S's share the same tranny?
When i did this way back when, this was the info i got from someone with the manual. I dont think he had the 00-03 manual so im going ot guess its all the same (until i can get my CL and TL electrical trouble shooting manual to verify)
I'm looking at the Electronic Troubleshooting manual and it shows the
following wiring for the 10 pin plug at the shifter (00-02)
Upshift - Pin #6
white w/ blue stripe (shifter plug side, male) to yellow (PCM plug side,
female)
Downshift - Pin #7
blue w/ yellow stripe (shifter plug side, male) to orange (PCM plug side,
female)
Upshift - Pin #6
female)
Downshift - Pin #7
female)
I can see where this would make sense. If anyone has ever ridden a motorcycle it's kind of the same motion. You're pulling up on the shifter to up shift, and pushing down to down shift. Here he's pulling to up shift, and pushing to down shift.
