How to bleed our ABS brakes????
Well with my old car, without mechanical tools, me and my frineds can bleed a brake, starting from the the brakes farest to the master cyclinder, then the next farest, and so on.... pumping, opening the valve andstuff.... but since our cars have ABS, HOW to bleed the brakes???? also, do yall know if we can get the Accord rotors and pads to put on the CL??? thanks
I found this from our brother site Acura-TL.com:
How to install Comptech Stainless Steel Brake Lines
As far as I know, all ABS cars have a seprate blead system for ABS. And only needs to be done if the ABS system is replaced, or worked on. Otherwise, the cars breaks are blead the normal way when replaceing pads, rotors & lines.
Jamus22
06-11-2023 10:08 AM
GWEEDOspeedo
01-15-2016 10:39 PM
